Is my box correct? - Car Audio Classifieds!
Old 10-26-2010, 07:57 AM
crownvicon26's's Avatar
0/11 sssss1882
Default Is my box correct?
My box is suppose to be 8 cubes net, tuned to 33 htz. The dimensions are: 21'' deep, 39.75'' wide, 25'' tall. The port is 5'' wide and 15'' deep. Is this correct?
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 10-26-2010, 08:33 AM
tntahoe's Avatar
0/11 sssss1196
im getting a port length of 25
Old 10-26-2010, 08:45 AM
0/11 sssss1882
Originally Posted by tntahoe View Post
gross volume 12.08
internal volume to be 10.14
port volume 1.17
net volume 8.97(still need to subtract woofers n bracing)
using winisd
to get 33Hz @ 8 cubes you need 25" of port length
I think sub displacement is .15 cubes per sub. My box is only 21'' deep so my port isn't 25'' so what would I be tuned to? Im still a newb when it comes to boxes.
Taramps 8k
2 Zv.3 15's
Old 10-26-2010, 09:03 AM
tntahoe's Avatar
0/11 sssss1196
since your box is 21" deep you would have to make an L port, with your current length the tuning would be somewhere around 39Hz
Old 10-26-2010, 09:12 AM
0/11 sssss1882
I dont know it its an L port or not. The port wall goes back 15''. Here is a pic of the box.
Taramps 8k
2 Zv.3 15's
Old 10-26-2010, 09:16 AM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
does the port turn 90 degrees and go along the back of the box...
or does it end at 15"
if 15" u are tuned around 39hz
TeamGG
Team D.O.A.
Old 10-26-2010, 09:19 AM
0/11 sssss1882
It ends at 15''.
Taramps 8k
2 Zv.3 15's
Old 10-26-2010, 09:22 AM
Decaf's Avatar
0/11 sssss3460
Originally Posted by Crownvicon24s View Post
It ends at 15''.
u could make a port plug and get down to ~35hz
since u shrink port area u gain cone control, and lower ur f3, in other words u can play lower more safely
so u can play more notes, but might not be as loud
TeamGG
Team D.O.A.
Old 10-26-2010, 09:25 AM
0/11 sssss1882
Whats a port plug? Im slow. Have an idea but don't know exactly.
Taramps 8k
2 Zv.3 15's
Old 10-26-2010, 09:32 AM
tntahoe's Avatar
0/11 sssss1196
you can try and add the extra needed length to the port but im not sure how long it needs to be
@decaf how long would the piece need to be to achieve 25" of port length, im assuming it needs to be 5" long
Correct port tunning. 12volt? bbp6? Brianyakno Enclosure Discussion & Design Construction Help 2 08-31-2010 02:38 PM
this would be 6th order correct? jj53913 Enclosure Discussion & Design Construction Help 25 05-25-2010 10:07 PM
Need an amp, need your help to find a correct one. Bologna General Car Audio Discussion & Questions 3 04-27-2009 08:52 PM
