Cooling fan question?? - Car Audio Classifieds!
Old 01-30-2009, 06:38 PM
0/11 ssssss289
Default Cooling fan question??
So i am building a false floor which will completly hide my amps, battery and wiring and was looking into cooling fans to help keep the amps from over heating(primarily during the summer). Wondering if anybody else has added cooling fans and had any info that could be useful when i install mine. Don't have a lot of knowledge when it comes to adding an electrical circuit without the risk of fire so any input at all would be appreciated.
Heres the fans i am going with, planning on getting 4 of them but that may change when i get them in my possession and see what they can do.
http://www.microbarn.com/details.aspx?rid=101546
Thanks in advance.
-Fink-
"It's not based on any particular data point, we just wanted to choose a really large number." a Treasury Department spokeswoman explaining how the $700 billion number was chosen for the initial bailout, quoted on Forbes.com Sept. 23.
Certified dealers Refs: C3 customs
Old 01-30-2009, 06:44 PM
Blackout's Avatar
0/11 sssss2427
I'm not to sure how it would workout because it would just be circulating heat (warm air) in a confined area... If it where all close off...
"I'm kicking you off my buddy list b*tch, I hope you & your computer catch a virus!"
Old 01-30-2009, 06:46 PM
Prohibited Sellers/Buyers
0/11 ssssss327
I would do an in and out setup.
Have 2 fans blowing air in and 2 fans pulling air out.
Keeps air circulating over the amps at all times
I also have 4 pimp fans I'll give you if you want to just pay shipping and a little extra for the time to box them up and ship them
Old 01-30-2009, 06:47 PM
0/11 ssssss289
Well, there would be an entrance(which is were the fan is) and an exit on the other side of the amps. So it would move fresh air from one side of the amps to the other side.
Old 01-30-2009, 06:49 PM
0/11 ssssss327
but its not pulling hot air out.
Best setup is a fan blowing in and a fan blowing out to pull the hot air out. Acts like a vent in an attic
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
I would put 3 on one side pushing air in and one on the other end pulling air out. IIRC positive pressure is better for cooling.
You just need to make sure they are 12V fans, (website is blocked) then run a relay off your remote wire on your H/U and have the relay power your fans. Just put a fuse in line of the relay and you should be good.
If you need more in-depth stuff I know madmatt or someone can help if I don't get to it first.
Team CACO Team SHOK
Supporting Member
Old 01-30-2009, 06:50 PM
0/11 ssssss289
much appreciated but like how these look and should perform quite well i beleive.
Old 01-30-2009, 06:52 PM
Blackout's Avatar
0/11 sssss2427
That would work great...
Old 01-30-2009, 06:56 PM
0/11 ssssss289
They are 12 volt fans, as for the relay thats were i get lost. I'll try googling the internet to see what i can find on the relays and what kind to get.
Old 01-30-2009, 07:00 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Just get a regular 4 pin relay from walmart or radioshack or something, and then wire it like this (going my memory and it's been a while, but I'm pretty sure it's right.)
Pin 30 +12V constant (Fused)
Pin 85 Ground
Pin 86 Remote from H/U
Pin 87 + of fans.
Wire the + of all the fans together in paralell, and all the - in parallel to the ground.
This way they all get the same amount of power and run at the same time.
Team CACO Team SHOK
Supporting Member
box question natisfynest General Car Audio Discussion & Questions 18 01-11-2009 06:40 PM
question.. s10 with 4 15's General Car Audio Discussion & Questions 1 01-11-2009 07:01 AM
Question DLP customs Talk with the staff 10 01-09-2009 09:46 AM
what up, got a question... impala60623 General Car Audio Discussion & Questions 17 01-07-2009 11:02 PM
RE box question tater Enclosure Discussion & Design Construction Help 10 11-03-2008 10:50 PM
