time for a proper enclosure. opinions\input plz. - Car Audio Classifieds!
Old 10-29-2010, 05:07 PM
808kikdrum's Avatar
team IAK
0/11 sssssss86
Default time for a proper enclosure. opinions\input plz.
Its time for the hdc3 15 d2 to find a suitable home. Currently in a very non ideal 4.6 cuft @ 30 hz with 88 sq.in. of port! sounds halfway decent on about 5 notes. no bueno at all. wanted to know what u guys think would be the most optimal size, tuning, configuration. On a 2200d @ 1ohm in the trunk of an 06 camry, daily, mostly rap. Appreciate all input.
Old 11-01-2010, 03:19 PM
808kikdrum's Avatar
team IAK
0/11 sssssss86
nothin? thinkin 4 cubes at 35hz, sub and port on same side. any other ideas?
Old 11-01-2010, 03:25 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
4.5 @ 34 hz.
Old 11-01-2010, 03:26 PM
3rdshiftdiscretion's Avatar
CACO Late Night Crew
0/11 sssss4240
Feedback Score: 30 reviews
3.5 at 38hz.... HDC3's love higher tuning because they drop off alot when broken in. My 18 is in a 36hz box and its moveeessss air
Bewbs
Old 11-01-2010, 03:31 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
3.5 is a nono
15s have higher fs
4.25-4.5cuft w/60-70sqin @ 35hz should do just fine and be plenty musical
with the extra port u have u make the roll-off faster and shrink the bandwidth
TeamGG
Team D.O.A.
Old 11-01-2010, 03:34 PM
0/11 sssss4240
oh crap sorry mistype!!!!!!!!!!!! i meant 4.5 at 38hz. Also they love alot of port area so make sure you "build your port and build the box within the port" if that makes sense
Bewbs
Old 11-01-2010, 03:36 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Too high
Old 11-01-2010, 03:38 PM
808kikdrum's Avatar
team IAK
0/11 sssssss86
love it, first two responses are 1cuft and 4hz apart. thats mostly what i hear r the two opposite ends of the spectrum, big and tuned low or smaller and tuned high. again this is for daily with a 2200d @1 playin mostly rap. thanks for the opinions, all taken into consideration.
Old 11-01-2010, 03:42 PM
Decaf's Avatar
0/11 sssss3460
i said 4.25-4.5 because its efficient and sounds good and is less peaky
i said 35hz because u are used to 30hz tuning, so i dont want to make a drastic jump to 38hz, and it will allow you to still play lower safely, songs like "Put On" or White Girl
TeamGG
Team D.O.A.
Old 11-01-2010, 03:43 PM
808kikdrum's Avatar
team IAK
0/11 sssssss86
saw this after already posting about the 1cuft difference, still higher than im gonna go, but thanks for ur opinion
Tags
audioque, box design, enclosure, hdc3
Opinions wanted on enclosure Thixx Enclosure Discussion & Design Construction Help 7 08-22-2010 04:05 AM
Long time listener, first time caller danssoslow New Member Orientation 7 09-16-2009 12:28 PM
Enclosure Adjustment Opinions aturcotte127317 Enclosure Discussion & Design Construction Help 13 05-06-2009 08:07 AM
Enclosure opinions Pioneer~Saturn Enclosure Discussion & Design Construction Help 61 03-13-2009 10:06 PM
