2003 yukon alternator - Car Audio Classifieds!
Old 10-29-2010, 06:04 PM
DYNORANDY's Avatar
0/11 ssssss146
Default 2003 yukon alternator
need alternator for 2003 gmc yukon i have 4 shurikens 2600 and and a 225 amp alt. now all wiring has been upgraded what amp alt. would i need to run 7k watts and how much
Pioneer Avic-920BT/Sundown Subs & Amps/Hertz Comps
Old 10-31-2010, 10:57 AM
MECHMAN's Avatar
0/11 sssss1142
I would reccomend keeping your 225 amp alternator, and buying our dual alternator bracket, and an additional 200 mechman alternator. The bracket kit is $369, and the 200 amp unit is $299. Our new 200 amp unit has MASSIVE output at idle, and would give you 425 amps total on tap all the time, with great durability. For $669 shipped, you would have a bad ass charging system.
Old 10-31-2010, 12:00 PM
DYNORANDY's Avatar
0/11 ssssss146
cool thanks i had the alternator built local and most are saying they are not reliable and they alternators does not do what they say mine is a 250 but only does 225 thats why i want a new alternator a 350 maybe and then a second if need and i am going to add 4 more shuriken 2600 cause i can fit 8 in my truck let me know what i should do
Old 11-01-2010, 04:38 PM
MECHMAN's Avatar
0/11 sssss1142
If you are unsure of the reliability of your unit, then I would use two of our 270 amp units and our dual alternator bracket kit.
regards
Matthew
Old 11-01-2010, 05:36 PM
DYNORANDY's Avatar
0/11 ssssss146
great what is the cost
Old 11-02-2010, 09:02 AM
MECHMAN's Avatar
0/11 sssss1142
Our 270 amp AD244 units are $399 each.
Re xxx15 2003 ultrabozobass General Car Audio Discussion & Questions 9 09-01-2010 07:40 AM
Re xxx15 2003 ultrabozobass New Member Orientation 2 08-31-2010 08:19 PM
[WTB] HO alternator for 00-06 GMC Yukon with 5.3 Sir-Lancelot Wanting to Buy (WTB) 3 01-23-2010 10:43 PM
200+ Amp ALTERNATOR (5.4 2003 Lincoln Navigator) 03navi General Car Audio Discussion & Questions 1 11-12-2009 11:47 AM
Need Alternator Help Yukon Denali crown_vic_driver General Car Audio Discussion & Questions 6 08-12-2009 08:10 AM
