what amp or amps( NEW BUILD) - Car Audio Classifieds!
Old 11-01-2010, 08:30 AM
0/11 ssssss125
Default what amp or amps( NEW BUILD)
OK here's the deal I want to compete in Usaci. I am doing this build with 4 -3512 dual 2 wired series/parallel down to 1 ohm to amp. Here is the design,
I'm trying to be in a good class. This will be walled off, so I was thing I would be in a modified class. The question is what amp or amps.
DD m3 1 2 or 4
DD z1a
DD m4a
Need some input, by the way battery bank now is 4 NGT extreme NG31's I can add 2 more if needed and a 250 amp alt with 160 at idle.
Old 11-01-2010, 08:54 AM
Andrew2944r's Avatar
0/11 sssss1226
Depends on what Mod Power class you want to be in on what amps I would run.
Old 11-01-2010, 09:04 AM
dB-r_Electronics's Avatar
0/11 sssss2834
All the mod classes are in the 160's. The amps will very much depend on what class you intend to compete in.
Shameless Capitalist
Old 11-01-2010, 09:05 AM
0/11 sssss2834
SB4 is also now in the 160's.
There are battery restrictions in all mod classes. Also in SB1-4.
Old 11-01-2010, 09:54 AM
0/11 ssssss125
suggestions?
Old 11-01-2010, 10:45 AM
0/11 sssss2834
What class? an amp good for 0-1000 won't necessarily be good for 1000-2000, or 4000+, even in multiples. Best to go to:
http://www.soundoff.org
And go into the USACi forums and see what other people are using in those classes. I think you will find a lot of:
RD D5
RD D9
IA 40.1
DD M3
AA 500.1
AB 200.1, 400.1, 500.1
And maybe a few others.
Old 11-01-2010, 09:27 PM
0/11 ssssss125
what about the American Bass VFL 1000.1, anyone ideas
[Sold]2 us amps vlx 400. two of the best amps on caco usampsman 2-Channel Amplifiers 19 03-31-2010 06:15 AM
I want a new amps/amps, any budget reliable suggestions?? .5-1ohm?? Vaginatarian General Car Audio Discussion & Questions 47 12-14-2009 11:38 AM
New Build - (2)RD3250V2 Amps kane0249 General Car Audio Discussion & Questions 54 10-27-2009 01:41 AM
4 Sundown E8 & Old school Orion amps Build Goindef154 Build Logs 49 09-29-2009 11:09 PM
[SOLD] zed audio made boss amps. 2 ch/4 ch sleeper amps! ampjunkielikeme 2-Channel Amplifiers 2 09-04-2008 05:25 AM
