Amp wiring (safe?) - Car Audio Classifieds!
Old 02-05-2011, 03:50 PM
JLAUDIO Bo1 901's Avatar
0/11 sssssss13
Default Amp wiring (safe?)
HOPE I PUT THIS THREAD IN THE RIGHT AREA BUT IF NOT MY BAD
I just recently bought a amp from this dude,that was selling it for dirt cheap and when i went 2 take a look at it, he had the amp wired positive and positive and same with negative 2 negative to the sub. is that a good idea to be wired like that? (as seen in the picture below)
amp is a RF p600bd1 going 2 a psi 15 wired down to 1 ohm amp can only give 2 ohm when he had it hooked up
Old 02-05-2011, 04:03 PM
Infinitelybaffled's Avatar
0/11 ssssss816
Yes, Thats safe. Does nothing but lower wire resistance and if anything that is a good thing.
Old 02-05-2011, 05:32 PM
0/11 sssssss13
aw i heard it shortens the amps life is that true?
Old 02-05-2011, 05:33 PM
Super Moderators
0/11 sssss9623
what kinda sub is that in your paint picture
Old 02-05-2011, 05:46 PM
0/11 sssssss13
iono lol kinda looks like a p3
Old 02-05-2011, 05:53 PM
TREETOP's Avatar
0/11 ssssss203
There's no "bridgeable" or "non-bridgeable" on a mono amp, it's just one channel- there's nothing to bridge. That amp has the two sets of outputs paralleled anyway, it only has two sets of connections for ease of wiring in some cases. You can hook just one side up, or keep it as shown, either way is fine.
Old 02-05-2011, 06:02 PM
0/11 sssssss13
aw ok thnx ,so is there a difference between hooking 2 up or just leave it 1 output,the seller said hooking up both outputs 2 one give it all the wattage from the amp is that true?
Old 02-05-2011, 06:11 PM
TREETOP's Avatar
0/11 ssssss203
The seller is misinformed. The two sets of output connections are paralleled inside the amp, won't make any difference- you'll get the same wattage using either set of connections alone.
Man Behind the Curtain
0/11 sssss1699
It doesn't change ohm load if you use one or both outputs. same power.
Old 02-05-2011, 06:47 PM
0/11 sssssss13
thnx 4 the info ill keep that in mind
Would it be safe too... Audio_Prodigy General Car Audio Discussion & Questions 5 09-18-2010 10:37 PM
Is there a safe way? davidrforbus General Car Audio Discussion & Questions 6 09-18-2010 04:49 PM
Better Safe Than Sorry NPHagert (Sundown Audio) 13 08-07-2010 09:37 PM
is there any safe way to.... newarkbeast973 General Car Audio Discussion & Questions 18 07-17-2010 09:50 PM
