2 t2000 15's - Car Audio Classifieds!
Old 02-10-2011, 06:47 AM
0/11 sssssss44
Question 2 t2000 15's
I have to t3 t2000 15's running off an audioque 3500 in a 2003 chevy impala. Need box size for my trunk and how many ports amp was cutting off after about 20 seconds of bass I had a kinetik 800 a Deka intimidator battery at the time. Now I have a 220 amp alternator a nsb 125 battery a yellowtop optima under my hood that I added with my other batts my amp shouldn't cut off anymore right?
Old 02-10-2011, 07:29 AM
iLLsT0LZ's Avatar
0/11 sssss1188
Feedback Score: 31 reviews
are you sure thats why your amp was cutting off cus of the voltage? whats the voice coil config of your t2000's if they are dual 2 you might be running your load down to .5 ohms and that could be why its shutting off also.
Old 02-10-2011, 07:32 AM
0/11 sssssss44
Yea they are dual 2's I am running it at .5 ohm when I added the other batts and alternator it's not cutting off anymore
Old 02-10-2011, 07:34 AM
Slammintriple6's Avatar
0/11 ssssss594
Also could be shutting off do to a loose ground!
All was check your grounds
0/11 sssssss44
Do you think I should get 2 dual 4 ohm 15's if so which ones?
Old 02-10-2011, 07:46 AM
iLLsT0LZ's Avatar
0/11 sssss1188
thats good its not shutting off anymore, if everything is working fine now and your happy with it why change? other than that if you wanted to what are you looking for more sq or spl and what kinda of vehicle do you have as well?
Old 02-10-2011, 09:35 AM
0/11 sssssss44
More street beating I have a 2003 chevy impala
Old 02-10-2011, 09:37 AM
0/11 sssssss44
How good are te Orion hcca 15.4's or the incriminator death penalty dual 4's
Old 02-10-2011, 09:34 PM
0/11 ssssss140
Stick wit T3. Just build a better box. That Mayb the reason Ur not satisfied
Real men run 16volts!!
btl or t3 t2000 alexis8284 General Car Audio Discussion & Questions 18 05-16-2010 09:26 PM
t2000 Bob Saget General Car Audio Discussion & Questions 3 04-19-2010 05:26 PM
2 - T2000 15's nathanallan General Car Audio Discussion & Questions 16 03-14-2010 03:47 PM
2x custom D1 15's + Dual 15's box w/ 10.5" Alum Flared Aero snb778 15" Subwoofers 13 02-08-2010 02:15 AM
(4) Memphis MOJO 15's reconed with FI parts WTTF for 2 B.A. 15's 18inchjeepin Car Audio Trader (WTT) 6 01-22-2010 04:30 PM
