dissapointed with 6.5 kappas. - Car Audio Classifieds!
Old 02-24-2011, 08:50 PM
MERQUE's Avatar
0/11 ssssss622
Default dissapointed with 6.5 kappas.
i just recently installed two sets of infinity kappas and wired them to a p450.4 and i am kind of dissapointed with their loudness. they're not as loud at i expected. they sound great but the highs are not what i was expecting.
the amp is rated 225rms X 2 @ 4 ohms, and i have it wired at 4.5 ohms.
the kappas comp set is rated at 90 rms, but the 6.5 says 90 rms on it and the tweeters says 50 rms on it.
does anyone have experience with the kappas? can they take more power? do you think it could be because of the slightly higher ohm load? if i give the comp set 140 rms it should split it 90/50 to the mid and tweeter correct?
before i bought the kappas i read a lot of reviews saying that they are very "bright" which they are but i love it, i was just expecting more.
Old 02-24-2011, 09:13 PM
SpeedEuphoria's Avatar
0/11 ssssss151
so you have the amp bridged?? If not your only getting 60w
they should scream or blow off 225w
'03 Dodge Stratus Coupe
'89 Dodge Spirit soon to run 10's
Old 02-24-2011, 10:43 PM
MERQUE's Avatar
0/11 ssssss622
yes the amp is bridged at 4.5 ohms.
Old 02-24-2011, 10:44 PM
um aren't kapa's 2ohm speakers?
Old 02-24-2011, 10:51 PM
MERQUE's Avatar
0/11 ssssss622
yes sir
Old 02-24-2011, 10:54 PM
MERQUE's Avatar
0/11 ssssss622
2.3 ohms actually.
i have the front wired in series to 4.5 ohm and then bridged on the front channels of the amp. same for the rear.
Old 02-24-2011, 10:56 PM
you can't wire a comp set in series? are you running 2 sets up front?
Old 02-24-2011, 11:21 PM
MERQUE's Avatar
0/11 ssssss622
why cant you wire a comp set in series? two sets up front and two in the rear?
i wired the wire going into the crossovers in a series to get the 4.5 ohms.
Old 02-24-2011, 11:22 PM
MERQUE's Avatar
0/11 ssssss622
would there be any difference in sound from going bridged to giving each comp set their own channel?
Old 02-24-2011, 11:46 PM
the way you said it, sounded like you had 1 set wired in series which can't happen
147.9 and im dissapointed sound_around General Car Audio Discussion & Questions 58 06-23-2009 02:56 PM
New system Dissapointed... Buddah_iii General Car Audio Discussion & Questions 15 02-22-2009 12:52 AM
