wiring issue - Car Audio Classifieds!
Old 02-26-2011, 02:21 PM
0/11 sssss1691
Default wiring issue
i have to run my 2 kicker l7's at 4 ohms then wire them together for a 2 ohm load is there a correct way to wire them as far as the coils should i be running the POS wire from the first coil to the second coil or keep it on the first coil and run off second coil ? idk if there is a right or wrong way to hook them up thanks any info will be appreciated
0/11 sssss1691
btw the subs are a a duel 2 ohms
Old 02-26-2011, 02:56 PM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
Look up rockford fosgate woofer wiring wizard
Old 02-26-2011, 03:16 PM
massivespl's Avatar
0/11 sssss8409
X2
Old 02-26-2011, 03:40 PM
Matt3824's Avatar
0/11 sssss3754
Tie the pos of a vc to the neg of that vc, do the same on the other sub, then on the other vc tie the pos of one sub to the pos of the other sub, same with neg, then to amp.
Old 02-26-2011, 04:12 PM
0/11 sssss1691
im just asking really is if it is being efficiant i dont feel like im using the subs to their potential this way or should i only use one vc on each sub?
Old 02-26-2011, 04:16 PM
0/11 ssssss133
No you should not
Old 02-26-2011, 04:22 PM
mtrevino92's Avatar
0/11 sssss1526
Feedback Score: 21 reviews
Default Depends
What final impedance are you trying to get them to? What amp are you using? If your amp give you power at a 2ohm load then wire them to a final impedance of 2 ohm. If it stable at a 1/2 ohm and you have the electrical for that, by all means go for the 1/2 ohm. Like the previous gent said, check RF woofer wiring wizard. It will point you in the rite direction.
Old 02-26-2011, 04:29 PM
massivespl's Avatar
0/11 sssss8409
JAYARE2007MAG....u already have another post just LIKE this one... Get a DIFFERENT amp so you can run the correct ohm load so you can run proper power to your woofers...im going from you said you have a BOSS 3000 amp in your other post..
Help! Amp issue? rxer311 General Car Audio Discussion & Questions 26 08-18-2010 04:45 PM
Wiring issue (ohms) linden General Car Audio Discussion & Questions 19 08-16-2010 10:11 AM
Issue with relay (i think) or wiring ryan_46307 General Car Audio Discussion & Questions 5 06-22-2010 10:33 AM
Amp wiring issue :/ D'90's General Car Audio Discussion & Questions 9 04-17-2010 11:12 AM
Alt issue help bumpin buick General Car Audio Discussion & Questions 6 08-02-2008 10:03 PM
