GM owners! Help with ground. VIDEO! - Car Audio Classifieds!
Old 02-26-2011, 07:57 PM
thisistiny's Avatar
0/11 ssssss663
Default GM owners! Help with ground. VIDEO!
Hey guys.
I drive an 05 tahoe. All my equipments are in my sig.
I want to know the best spot to ground my amps. Where do you guys ground them?
Amps are under the 2nd row seats. I know it's a mess but I'm planning to build an amp rack after i hook up everything properly.
I have this hiss from my door speakers that i can't get rid of. even after i changed the ground spot. hiss does vary with different RPM's (you'll see in the vid) hiss is not bad at all. most people probably won't even notice it, BUT I CAN! haha and it's bugging the sh*T out of me.
I'm aware of the pico fuse deal with pioneer decks. I bought the HU couple months ago brand new and been very careful about hot swapping the RCA's. So i don't think it's a pico issue.
Only thing i can think of is maybe adding another gound on my HU. I have all my accessories for my HU, XM module, steering wheel control, and the parking brake bypass all tapped into the same ground wire for the HU.
Hope that makes any sense.
and here is the vid...
http://www.youtube.com/watch?v=tNDxHxqyYT0
i hope i didn't drill into the gas tank for the new ground location. Don't know why, but i'm really paranoid about that. haha. screw is about an inch long.
'05 Tahoe
HU: Pioneer AVH-P4200DVD w/ XM add-on
Fronts: Crescendo CCX65
Rears: Alpine SPS-600
Powered by: Sundown SAX-100.4D
Subs: JL Audio 2 10w7 - 3ft^3 @ 35hz
Powered by: Sundown SAZ-1500D
Old 02-26-2011, 07:59 PM
Team Roto Rooter
0/11 ssssss459
seat belt bolt? and u have your rca's wire tired to your positive wire and clean the mess up first and go from there
----------------- BoomVada -----------------
Old 02-26-2011, 08:01 PM
thisistiny's Avatar
0/11 ssssss663
Originally Posted by Sinister-David View Post
seat belt bolt?
the bottom bolt of the seat belt? on the side of the car by the floor, correct?
'05 Tahoe
Old 02-26-2011, 08:04 PM
loudrango's Avatar
'05 IASCA World Champ
0/11 ssssss881
if you use that for a ground,make sure you sand the paint off before grounding.
-Team Noisyboyz re-est 2010
-Team DC Audio
-refs:thorshammer,toolmaker,tinted,k312ock,moparbum pin,
defj145,scottiej,woofercooker,teamcartunesjeff,spy ,bread0710
acceleratorz,jaggededgekustomvinyl,toolguy420
Old 02-26-2011, 08:05 PM
Team Roto Rooter
0/11 ssssss459
yea like above said make sure u remove all paint/rust anything there first then ground there and any of the seat belt bolts work great
Old 02-26-2011, 08:09 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
I would start with the HU ground and fix that first.
/ CAAA Member #2 /
Old 02-26-2011, 08:14 PM
NoPh33rRaCiNg's Avatar
I <3 ( . )( . )'s
0/11 sssss3010
Feedback Score: 29 reviews
I had to ground the rca outputs on the deck and ground the deck to the chassis in my 02 that fixed the noise on my new deck. And for the rear I have my kinetiks grounded to the chassis under the carpet in the back, and my amps are grounded on the kinetiks
Team DC Audio : Team NWSPL : Team Shok
02 Tahoe - (1) 15'' XL, Shok II, Shok 1/0
03 S10 (in progress) - (3) 15'' Lvl5's, (2) DC 5k's, lots of Shok 1/0
Old 02-26-2011, 08:18 PM
0/11 sssss1463
Feedback Score: 21 reviews
I know my TB has these so Im assuming the Tahoe does but there are points in the back where you can tie stuff down, there triangle looking metal peices that flip up and down. The screw on them is a torx head that goes all the way through the body. I used that for my ground but i went down to complete metal on both sides of the triangle thing and on the floor.
Contact me to get orders for any of your B2 Audio needs. I am an Authorized Dealer
REFS-DAPPA5, BRIAN OWENS, --Navi-- , X1le, Basscort2009, vitveet, thumpper, Lousiana_CRX, woofercooker, tez4life, 913 customs, davidrforbus, bluieorbluee, lil98cabrio, Dropped_TB, orangecounty1, dbeez, Seifert, JB Livewire, rmaravetz, 72impala
Old 02-27-2011, 01:13 AM
thisistiny's Avatar
0/11 ssssss663
Thanks for the input guys. I'm def going to try and run another solid ground from my HU.
Would doing the big three have a chance of fixing the whine? I know it needs to be done anyways. Just curious.
'05 Tahoe
Old 02-27-2011, 08:53 AM
massivespl's Avatar
0/11 sssss8409
i have an 2002 tahoe...i tryed the seat belt ground and it was junk... then i stripped the paint and Bolted it to the Body under the seat.... made a big difference with a proper ground...as for the noise you hear out your speakers is it white noise? in my Tahoe i have the same lil hiss noise and its white noise and i cant get rid of it either
any rsx owners? korey_hofer Off Topic Chat 10 09-14-2010 02:16 PM
? for aq2200 owners or ex owners notloudenuff General Car Audio Discussion & Questions 31 05-28-2010 05:07 PM
Maxima Owners and Trunk Owners Please Look Inside! strpperpolef150 General Car Audio Discussion & Questions 13 06-06-2009 09:13 PM
DLP Owners: toyota thundra General Home Audio/Video 14 02-12-2009 01:58 AM
