electrical questions - Car Audio Classifieds!
Old 02-26-2011, 08:21 PM
0/11 ssssss185
Default electrical questions
i have a 72 c10 and i bought a iraggi 260 amp alt im about to buy batteries ... my amp that i am running is a ap3k im going to run a mid and high amp but i have yet to decide on the batteries or mid/high amp i was thinking about 2 deka 9a31 and a good battery upfront .. what kind of wire do i need ? i know i need ofc 1/0 but how much ? i am thinking of having the batteries under the bed (for traction cuz im attempting to make it fast as well/where else could i put them?) so my question's are what kind of batteries how many ? which one up front? which wire ? how many feet? my mids and highs are 6.5 5.25 and 2 tweets all mb quart if that matters sorry for the long post and thanks for the answers in advance!
Old 02-26-2011, 08:52 PM
0/11 ssssss185
nobody?
Old 02-26-2011, 08:57 PM
0/11 ssssss133
How much wire is something that really only you can find out really. Not too hard to get a basic idea though. Example. My '66 plymouth, the cable needed to go the length of front fender + the width of the firewall, then it went into the car. So length of cabin + length of fender + width of car = almost what I needed. Have to give some extra slack for getting around shit in the vehicle.
Wire is one thing that even I don't skimp on. It's re-useable at least. After using it, I will never use anything except this Kicker Hyperflex personally.
0 experience with batteries though.
Old 02-26-2011, 09:12 PM
0/11 ssssss185
thanks man .. how many feet did you use?
Old 02-26-2011, 09:22 PM
Kingdom of Solitude
0/11 sssss1254
the deka's will be a good choice for the secondary amp battery. I have a total of 4 deka 9a31's on jus 1 ap30001D i havent started my install but it all should work jus fine on a mechman 270amp alt in a 96 Grand Marquis as for the front i would use the next size up battery for which the truck can take. as for wire you can go with any wire as long as it True to Spec. i recommend knukonceptz kollosus although i use the KCA i am doing 6 runs total 3 neg 3 pos. * in a system you wana keep lengths of cable as short as possible to minimize resistance across the wire. this keeps stuff cool and the ap amp isnt really nown for being high build quality
Old 02-26-2011, 09:35 PM
0/11 ssssss185
4 dekas a upfront batt and a 260 amp alt you think ill need that many for say just 3500 watts ? i know the ap isnt the most efficent but still . do you think their is any better options for the cash
Old 02-26-2011, 09:37 PM
0/11 ssssss133
I needed over 20', but that was in a 4 door 66 Fury II. My Trooper needed at least 6' less
Old 02-26-2011, 09:41 PM
Kingdom of Solitude
0/11 sssss1254
naw i use the method a guy name mistrass told me with Dekas 2 9a31's per 3000 watts. but i have two AQ HDC3 15 and i plan to get another ap30001D or jus get an Crescendo Audio BC5500 wenenver it comes out.
but on a serious note u want to sometimes over do it wen it comes to electrical. my system as it is now with 1 amp i get virtually no voltage drop. from 15.3V COLD 14.3V HOT
Old 02-26-2011, 09:42 PM
Kingdom of Solitude
0/11 sssss1254
this is of course at like 85-90% full tilt
Old 02-26-2011, 10:04 PM
0/11 ssssss185
i understand the over do it but im just doing the minumum for right now and adding on later
Is this enough electrical? LyferXB9s General Car Audio Discussion & Questions 24 10-15-2010 08:02 AM
electrical help JusRsounds General Car Audio Discussion & Questions 1 03-13-2010 10:22 AM
Honda CRV electrical.. Questions! andrewtexas123 General Car Audio Discussion & Questions 2 01-15-2010 01:33 PM
electrical help JusRsounds General Car Audio Discussion & Questions 8 10-14-2009 05:12 PM
Electrical Help RidnClean General Car Audio Discussion & Questions 17 09-14-2009 07:14 AM
