Grounding Ideas, Build Help - Car Audio Classifieds!
View Poll Results: Ground Option
1 3 60.00%
2 2 40.00%
Voters: 5. You may not vote on this poll
Old 02-26-2011, 08:25 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
Default Grounding Ideas, Build Help
Alright, so I am throwing back and forth the idea of the build on my Malibu. It's a daily rider that will compete in SSNW. I am throwing back some ideas and have heard from each side, but I can get a larger group of ideas online then I can talking to individual people. I would put this in the build log, but I am putting a poll with this, and can get more responses faster with a new thread. This would be a place for some useful information to others as well. There are my 2 areas of thought. I am doing 2 runs of 4/0 wire, and have these 2 possibilities.
1. Run one wire hot (positive) and one ground (negative). I always thought that this would be the proper way to go. Make a complete circuit (modern theory of current flow) of alternator to front battery, through wire to back battery, into the amplifier, into the subwoofer, back to the amplifier, back to the back battery, through the wire to the front battery, and to ground. I never really thought of option 2 seriously until it was brought to my attention today.
2. Run both wires hot (positive) and ground (negative) one in the front and one in the back, using the cars frame to proved a closed circuit. This makes more current flow possible, and does not use the wire as a source of power if the car is off. This provides more power when the car is on and the alternator is running, but less when it is off. Since I would be competing with the car on and obviously driving with it on, this is now also an option.
I am putting a poll in this for popular vote, but the main decision will come with proper explanation of answers. Please provide. Thanks guys!
-Steve
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 02-27-2011, 08:13 AM
0/11 sssss3784
Other opinions..?
empty trunk
DC Power 270xp
.... so far
Old 02-27-2011, 08:20 AM
0/11 ssssss489
Lol I did both just to make sure and since it will take the path of least resistence its a win win for me
Old 02-27-2011, 08:23 AM
Team Roto Rooter
0/11 ssssss459
i would run both a postive and a negative from the front to the back battery and run the amps right off the back battery if i was u wire. run from alt + to front batt then from that batt to the + to the back batt then take the ground from the alt to the back battary then from the back battery to the front that way the alt is seeing both batterys as one
----------------- BoomVada -----------------
Old 02-27-2011, 08:42 AM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
get a 3rd wire and run 2 positive between batts and 1 negative between batts... and also use the frame grounds... then u have best of both worlds for an extra ~$50-75
TeamGG
Team D.O.A.
Old 02-27-2011, 07:41 PM
0/11 sssss3784
Maybe if I can get away with it, might not have enough after a big3 in 4/0!
empty trunk
DC Power 270xp
.... so far
Old 02-27-2011, 09:11 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Current flows from negative to positive in a battery. So grounding to the frame does not increase effencey. The ideal way is to do 1 and 1. IMO
Old 02-28-2011, 12:56 PM
0/11 sssss3784
I know it does, I think 1-1 will be the way to go, just gathering information. Always a good idea.
empty trunk
DC Power 270xp
.... so far
Old 02-28-2011, 12:57 PM
0/11 sssss3784
Well there are more votes for option 2, but no one has spoken up!
empty trunk
DC Power 270xp
.... so far
Old 02-28-2011, 01:05 PM
jnralp00's Avatar
0/11 ssssss606
As decaf said, do both. I have 2 runs each to back and also have back batteries going to chasis.
Ideas for my trunk build Legendary754 Enclosure Discussion & Design Construction Help 2 08-13-2011 06:58 PM
new build ideas LoudCavi General Car Audio Discussion & Questions 16 01-10-2011 12:43 AM
New Build Ideas bwe45 General Car Audio Discussion & Questions 20 09-16-2010 12:19 PM
First Wall - build it in car?? Need creative ideas Vaginatarian General Car Audio Discussion & Questions 32 03-01-2010 03:43 PM
