Kole Audio TRAX1-7000d good amplifier? - Car Audio Classifieds!
Old 02-27-2011, 02:46 PM
0/11 sssssss60
Default Kole Audio TRAX1-7000d good amplifier?
Here's a test of power:
amp test kole audio 7000
Real power in it?
Is he worth its $ 300 for a new amp?
Stably in 16v? Which will increase from 12v to 16v?
Old 02-27-2011, 02:52 PM
0/11 sssss3526
They had to wire to .5 to get 2.3k? For 300$? Better deals can be found, thats likely clipped power as well. Depending on impedence needed, an AP3k will do rated. You can likely get about 2.3k out of the 2600w brutus as well without having to wire to .5..Heck even a discus 2k will do near that without being wired to .5....although this DOESNT account for rise....I dont know, I would look elsewhere
Team Flex Issues
Temp build
Jvf Custom ssx 12 on DSC 1500
Xs Power
Hertz/Image Dynamics
Old 02-27-2011, 02:57 PM
thehawk93's Avatar
0/11 sssss3732
Real power in it?
I would stay away from this amp and save alittle more money and get a amp worth the money..
Old 02-27-2011, 02:58 PM
0/11 sssssss60
Why?
Old 02-27-2011, 02:59 PM
1loudyukonxl's Avatar
0/11 sssss1569
2300 rms after rising to 2.1 is not bad for 300 bucks
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 02-27-2011, 03:00 PM
0/11 sssssss60
I live in Russia. Buy a good power at low cost in my country is unreal ... But this can be purchased with delivery for $ 400, which to me cheap.
Old 02-27-2011, 03:13 PM
0/11 sssssss60
Planet Audio BB2400.1 and RDX2400 better than him?
Old 02-27-2011, 03:18 PM
massivespl's Avatar
0/11 sssss8409
that amp isnt even .5ohm stable. so you should not run it in .5ohm....so those number are junk...
Features:rms @ 4 ohm: 1 x 2200wrms @ 2 ohm: 1 x 3200wrms @ 1ohm: 1 x 4100wdimensions: 2.25"h x 10"w x 21.625" lregulated pwm power supply1 ohm load stable bridged synchronization (strap amps together for double power) 200mv-6v low level inputspre-amp outputsvariable 12db 40-200hz lpfvariable 12db 20-50hz subsonic filter variable 0-18db 45hz bass boost frequency response: 15-150hzsignal to noise ratio: 100dbtotal harmonic distortion: .5% direct input 0 ga. power terminal (5500d & 7000d)weight: 15.62 (lbs
Old 02-27-2011, 05:13 PM
Fly ty 215's Avatar
0/11 ssssss479
If u do get a kole the get the qx 2400 or 3000 the new kole stuff is trash but the qx series is hard to find but if u do it is worth the money good luck
Old 02-27-2011, 05:17 PM
0/11 sssss3344
so i shouldnt run my sundown at .5 cuz it doesnt say it can please enlighten me on this
sundown nutthugger
so dont hate!
refs ssackett spy resko cruzin22z 1loudyukonxl bumpinbuick theemichealhughes ss audio 2loud4youmorris atsaubry crxbumpin pshcyoacoustics big c yukon crescendoaudio skatinbassplaya keifersracing getlow galaticmonkey getlikeme bass14 twisted turdfurgueson2 enemyofsilence taylorpro duran anton miller kowboy willie3719 kickerassman
TEAM SUNDOWN
TEAM EVO
TEAM INCRIMINATOR
TEAM BETTER LUCK NEXT YEAR
TEAM WHATS A WALL
3 kole audio kmx-12's beatin_flub Car Audio Trader (WTT) 0 04-19-2010 08:45 PM
looking for kole audio kmx-12 Josh Wahlie Wanting to Buy (WTB) 1 02-25-2010 12:06 PM
Kole audio KX1-4000d mads10bass General Car Audio Discussion & Questions 0 07-18-2009 06:45 AM
Kole Audio TRAX1-7000D SPL-Master General Car Audio Discussion & Questions 2 05-21-2009 06:33 PM
