Beefing up my car system - Car Audio Classifieds!
Old 02-27-2011, 03:41 PM
0/11 sssssss29
Default Beefing up my car system
I accidently posted this in the orientation section, but I still need help with this so any help would be appreciated.
"Ok so I have in my car 2 AQ 2200 D's (strapped at 2 ohms) and a cresendo 1000c4, I am trying to get it to where I can stop at a light or in a parkinglot without it dropping below 13 volts on my meter ( right now it falls to about 12.1 , I have only seen it fall below 11 once).
As it sstands I have a 220 amp mechman alt, XS D3400 up front, XS D2700 in back, 2/0 big three, and Shok 1/0 comp wire through out (2 runs from front to back batts). What would you all suggest I do in order to keep it above 13 volts while idling?
PS: while driving or anything above 1K rpms I am at a constant 14.0-14.3 volts occasionally dipping to about 13.8 at the lowest."
Old 02-27-2011, 03:43 PM
0/11 sssssss29
It was already suggested to add more of a battery bank, but how big and what kinds ( I have a 09 sonata so not alot of room but I make due but putting the batts in the wheel well).
I am thinking should I add in another 2700 or go bigger and get a 3100?
Old 02-27-2011, 03:48 PM
brian_smith06's Avatar
0/11 sssss1109
I would add another 2700 to the rear and add until you are happy. However I would also consider selling off current current rear battery and getting a 3100.
My rule of thumb is one battery per 1000 watts in a system. Front battery not included
04 Tahoe Z71
Pioneer AVH-X5700BHS
Eric Stevens 2xQ700.2 1xQ1200.1 Modified for hearing pleasure
Seas Twiddlers, Silver flute 6.5", Alpine Type S 10"
Second Skin/lots of dynamat
Old 02-27-2011, 03:49 PM
0/11 ssssss647
Feedback Score: 21 reviews
i would do that also. i had a D3100, a D1200, a 250 mechman alt with a saz-3500 and never droped below 13.8 full tilt. wich isnt to bad
Old 02-27-2011, 03:51 PM
0/11 sssssss29
would I have problems if I just added a 3100? The 3400 and the 2700 are both about a month and a half old
Beefing up my electrical system (help) GhostMemphis New Member Orientation 3 02-27-2011 03:21 PM
my new system jason Member Rides & System Pictures 12 07-08-2010 01:31 AM
New system... RetroAudioInc Build Logs 5 01-20-2010 08:53 PM
help with new system 225HONDABOY General Car Audio Discussion & Questions 4 12-24-2009 08:15 PM
New system tyler gray Wanting to Buy (WTB) 1 05-31-2009 03:14 PM
