2x HDC3 12 (d2) copper box - Car Audio Classifieds!
Old 02-27-2011, 04:14 PM
0/11 sssssss29
Default 2x HDC3 12 (d2) copper box
How do you all think a box built for 2 hdc3 12's will perform if it is 5.5 cubic feet ( before displacements) with 1 6" aeroport tuned to 34 hz?
Old 02-27-2011, 04:24 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
you will want at least 1 more port, or 1 single 8" port
thats not going to be enough port area for that large of a box
TeamGG
Team D.O.A.
Old 02-27-2011, 04:27 PM
0/11 sssssss29
This is before displacements just fyi after displacements I think it's about 4.5 though. Should I just add another 6" or will the 8" be the better option over the two 6" ports?
Old 02-27-2011, 04:36 PM
Decaf's Avatar
0/11 sssss3460
what are the outer dimensions, i dont want to guess what would work
2 6" would be longer than 1 8"... but 8" are hard to find unless u use concrete tubes
TeamGG
Team D.O.A.
Old 02-27-2011, 04:43 PM
0/11 sssssss29
36W x17H x19D these are external measurements
Old 02-27-2011, 04:48 PM
Decaf's Avatar
0/11 sssss3460
ports will be too long to fit inside the box fyi
if using an 8" u will only have 4" from back wall
(assuming u are tuning to ~38hz which is typical of this sub, any lower and the port has to be longer)
TeamGG
Team D.O.A.
Old 02-27-2011, 04:53 PM
0/11 sssssss29
That sucks. So what would you suggest to do? these are going inside the trunk of a sonata the measures (30D x 19.5H x 38W) this is the max that would fit through that trunk opening.
Right now I have them in a box that is severely limiting them it is about 4.0 cubic feet before displacements.
P.S. I am tuning it to 34 due to me wanting killer low end bass.
Old 02-27-2011, 04:58 PM
Decaf's Avatar
0/11 sssss3460
personally i would just extend the depth another 3-4" so u can use a slot port instead... easier to build and way more port area
TeamGG
Team D.O.A.
Old 02-27-2011, 05:02 PM
0/11 sssssss29
OK one last question do you think that with it tuned to 34 HZ i will lose alot of the beat that it has in the higher ranges? and will I gain a noticable amount in the lower end? As it stand with songs like put on from jeezy I don't even hear the lowest notes...
Old 02-27-2011, 05:09 PM
Decaf's Avatar
0/11 sssss3460
having more port area and a larger box will benefit u more than tuning would at this point
that song is 28hz tho, which is pretty low
TeamGG
Team D.O.A.
18 hdc3 copper or 15 t3 t1000? its_ray_ray General Car Audio Discussion & Questions 11 08-03-2011 02:30 PM
hdc3 10 d1 copper t/s params? perfect_prefect General Car Audio Discussion & Questions 5 02-23-2011 12:21 PM
FS:18" HDC3 Copper SPLLuminator 18" Subwoofers 37 09-14-2010 04:48 PM
[SOLD] AQ HDC3 12inch copper chris the man Car Audio Trader (WTT) 27 08-10-2010 09:46 AM
WTT 15" D1 copper coil hdc3 Tkelly 15" Subwoofers 11 01-08-2010 01:19 AM
