feedback through subwoofer - Car Audio Classifieds!
Old 02-27-2011, 05:15 PM
TNJ
0/11 sssss7882
Default feedback through subwoofer
A team member got a sub built and installed today, the issue is he is now getting a feedback through the subwoofer. the volume can be on 0 and he still gets a feedback through the sub. he says when he revs the engine it changes pitch, its not a whine but a pitch. the only thing that was changed was his back battery got larger wire and a new ground spot. both John (violence.) and myself ground down the ground spot in the trunk and upgraded his wire to welding cable 2/0. john ran rcas from his hu to the trunk of the car to the amp outside of the car and it still makes a noise in the kids car. he is on his way to my house now to swap amps and were gonna try a ground loop isolator to try to figure out if its a ground or not.
what do you guys think it may be? i got like 45 minutes til he is here. time is of the essence. thanks CACO
TNJ
0/11 sssss7882
he did not have the feedback before the sub install and wire upgrade. but now he does. forgot to mention.
Old 02-27-2011, 05:19 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
Feedback Score: 41 reviews
no sub leads touching anything or loose connections.
brand new rca ran outside the car to trunk away from all power wires. rca's are knu karma kables.
ground for back batt fresh ground down to bare clean metal
sub wires read fine. read 1 ohm at amp and sub enclosure.
headunit at 0 feedback is strong through sub
remote lead doesnt seem to have a break in it and is ran with power cables.
only thing done today was box was slid into place with sub already installed and amp put back in its place. now he has an issue.
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
RCA ground issue
92 Ranger Walkthrough
(Under Construction)
Old 02-27-2011, 05:20 PM
TNJ
0/11 sssss7882
Originally Posted by RidnClean View Post
RCA ground issue
would it be rca or the hu itself?
Old 02-27-2011, 05:21 PM
cotyballs's Avatar
0/11 ssssss258
I dont know if the RCA's were ran near the power cable but that will cause a noise but its more of a whine. However this noise will change with the Rpm of the motor. Also try a better ground point actually on the frame. The body could have a wire somewhere grounding out on it or a power wire causing it to not ground properly. Sometimes I have also noticed an amp will cause this. Kicker amps are notorious for causing noise in my own experience. I am pretty new to audio (4 years or so) but I have been a mechanic for a long time.
Uncle Cooter Is Here To Boom
Bought From- Woofercooker, Banginkota, Twistedchild420's OPTI,
Sold To- Alexis8284
Traded With- Wes669
Old 02-27-2011, 05:23 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
My brothers would mimick the sound of the door shutting. It is his ground. Tighten it!
RidnClean's Avatar
Ballin
0/11 ssss17858
had this issue happen when i had the expedition.
my JVC never did it, but when i swapped to the pioneer, it came up.
grounded the RCAs on deck and issue went away.
had it also happen when i had a pioneer in my blazer, issue was needed new ground again.
TNJ
0/11 sssss7882
rcas were ran outside of car away from power wires. amp is grounded to battery, batter is grounded to what i believe is bumper frame, idk its a honda. big as s bolt found in trunk grounded back battery to.
Old 02-27-2011, 05:24 PM
TNJ
0/11 sssss7882
battery or hu one?
i had the issue with my pioneer as well, got my kenwood and no more issue.
how much I-trader feedback do you need..... crownvic97 Off Topic Chat 11 02-10-2011 07:14 PM
need some feedback luises14 General Car Audio Discussion & Questions 9 06-18-2010 01:47 PM
Db-R Feedback worstenemy453 (db-r) 9 10-08-2009 11:26 PM
feedback how to? ChampagneCavalierTT Announcements - Suggestions - Feedback - Support 1 07-23-2009 07:22 AM
Feedback thread DLP customs Off Topic Chat 0 10-29-2008 10:48 PM
