Let's talk mid-bass. - Car Audio Classifieds!
Old 02-27-2011, 05:58 PM
0/11 ssssss617
Default Let's talk mid-bass.
From beginner to advanced...
Have a 04' F150, looking for mid-bass solutions.
What do you guys do?
Tri-amp?
Running a 600w monoblock to a 12" sub, thinking of adding an 8", but I don't want frequency cancellation. Custom doors etc a little esoteric for now, but not out of the question.
Thought?
Old 02-28-2011, 03:26 PM
0/11 ssssss617
Bump.
As it were.
Old 02-28-2011, 03:30 PM
ltr450racer690's Avatar
0/11 sssss3414
well just a good set of component speakers sounds like they would be a good upgrade for you and will prove some midbass.
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Old 02-28-2011, 03:32 PM
you don't need 8's, 6.5's be much easier to use. 8" midbass would probably over power your subwoofer
Old 02-28-2011, 03:33 PM
0/11 ssssss617
I have infinity reference components with crossovers, doors dyna-matted, they just aren't cutting it for frequencies of (roughly) 250-1000(?)
Does this make sense?
I am a bass player, and would like to get more punch/spl for bass solo runs up the fretboard, that sort of thing.
It's all about SQL and balance, if I can find it.
Old 02-28-2011, 03:34 PM
0/11 sssss5305
Mach5 mli is worth looking into, especially at the pre-order price. I've been very happy with the AA carbon fiber mids and have used them with a 63Hz HPF...
Old 02-28-2011, 03:35 PM
DarkScorpion's Avatar
0/11 ssssss291
Most components should play midbass pretty well, but a lot of it gets lost due to a poor installation. Sealed and deadened doors would be the most ideal without resorting to custom pods as you suggested. Best way to do this? Aluminum flashing from your local hardware store, some good adhesive, ample deadening, and some patience. Sealing up the access holes in your doors will make the door seem closer to a "sealed" enclosure for the mids and will really help bring out the midbass. Also, power helps
Old 02-28-2011, 03:38 PM
Prohibited Sellers/Buyers
0/11 ssssss607
what amp do you have on your components?
maybe you have settings that are eliminating bass, like a high pass filter set to high
Old 02-28-2011, 03:40 PM
0/11 ssssss617
Currently not much power (MTX 50X4), but it's still damn loud. I have tried the HP at lower settings at the bass overwhelms the mids, and it sounds like shyte. (buzzing, etc)
Old 02-28-2011, 03:44 PM
0/11 ssssss617
Originally Posted by DarkScorpion View Post
Most components should play midbass pretty well, but a lot of it gets lost due to a poor isntallation.
I was kind of thinking along these lines (after all, I installed it, so it's gonna be wonky!)
One problem I have is broken door tabs. Any clean fixes for that? (It would be hard to seal tight without functional tabs). I trimmed my dynamat to create a seal around the door, (more for vibration) but yeah, there are TONS more places on each door/panel that air would bleed from unless I got crazy with it. It would be awesome to make a two speaker 'pod' that could go from vehicle to vehicle...hmmm....thinking dangerously expensive and impractical solutions...stop me...
Expedition talk Whitymanne General Car Audio Discussion & Questions 37 11-17-2010 09:19 PM
I think the dog can talk... madmat Off Topic Chat 12 09-25-2010 08:16 AM
Hello All I'm new here so talk to me... AudioInstaller New Member Orientation 13 05-17-2010 07:27 AM
let's talk nightshades splvictim20 General Car Audio Discussion & Questions 0 02-12-2010 10:40 AM
