3 Sub Impedance Question - Car Audio Classifieds!
Old 02-27-2011, 09:34 PM
0/11 sssssss11
Default 3 Sub Impedance Question
Okay, so when you wire three subs together, there are always weird impedance numbers. It's never a solid one or two ohm. It's always some strange decimal.
Example:
So I was wondering, what if you wired, say, two dual 1's together for a 1 ohm load, then wired a dual 2 to a one ohm load and plugged them all into the amp, would the third sub be in phase or all out of wack?
I just want to know if this will work out, because then you have all three subs together on a solid 2 ohm load.
Old 02-27-2011, 09:39 PM
Ballz out!
0/11 ssssss203
Whats wrong with the 1.33 load? I dont think what your talking bout will work bud.
Old 02-27-2011, 09:42 PM
0/11 sssssss11
Well, nothing I suppose. I am looking for a 2 ohm load though.
Old 02-27-2011, 09:43 PM
FatBoy2's Avatar
That was crafty.
0/11 sssss1790
It will never be a solid 1ohm, or 2ohm. Ha.
Even if you're wired at 1ohm, 2ohm, 4ohm, 8ohm or whatever. It's constantly changing. I don't get why 1.33ohm bothers you?
Fo eights in da pickup!
Old 02-27-2011, 09:44 PM
Ballz out!
0/11 ssssss203
Whats the starting impedence of your subs?
0/11 sssssss11
AP 3000D [email protected]
I was saying theory. I want to know it will work before I buy them. For the instance I am asking: 2x 1 ohm dvc and 1x 2 ohm dvc
Old 02-27-2011, 09:50 PM
Ballz out!
0/11 ssssss203
Simple answer NO! Get two dual 2's or 4 dual 4's anything in between that will be a like what you posted up above
Old 02-27-2011, 09:53 PM
0/11 sssssss11
Alright, thank you.
And just to clarify, the two dual 1's are wired together, and the dual 2 is wired by itself, then just the leads will plug into the amp. Adding the loads together will create then 2 ohm load.
Old 02-27-2011, 11:04 PM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
When u install the wires into the amp it will change the load to 1.33 again. Just b/c u don't have the third sub hooked to the other two and have a 2ohm load when those wires touch other subs wires it will not be 2 ohm. It's just wired down in a dif location.
Old 02-27-2011, 11:05 PM
OCD Member
0/11 sssss5696
Someone correct me if i'm wrong. Lol
Impedance Rise quaddropper General Car Audio Discussion & Questions 10 01-31-2011 12:52 PM
Impedance rise Bigbodylexus (Sundown Audio) 6 11-16-2010 12:20 PM
impedance rise AND Win ISD..... rawlins87 General Car Audio Discussion & Questions 7 08-07-2010 10:56 PM
question about impedance rise Craig28 General Car Audio Discussion & Questions 11 07-16-2010 02:54 PM
box and impedance rise MiX General Car Audio Discussion & Questions 20 05-26-2010 06:31 PM
