Electrical help: suggest me some things - Car Audio Classifieds!
Old 02-28-2011, 08:02 AM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Feedback Score: 30 reviews
Default Electrical help: suggest me some things
I've been running my system, dropping to the low 11s at idle/full tilt, and I want a rock solid electrical for demoing and basic safety of my equipment. Can you guyd provide me with some help in how to achieve that. This is a daily system only, no comps, just hard demoing.
Right now I run:
2 Audiopipe 3ks
2 Audiopipe 200.4s
2 Treo SSX15s / 2 Orion HCCA15s
4 Selenium 6s
2 SS Supertweets
1 of each positive/negative 1/0
220a alt
XS Power VCM
Stock front, and 2 Deka Intimidators in the rear.
I was thinking of buying different 3k amps, but I think I'd still have voltage issues running 6k no matter what amps I used. Help me out. I want to hold at least 13s full tilt, at idle
Audiopipe Nutthuggery at its finest
Old 02-28-2011, 08:05 AM
Super Moderators
0/11 sssss9623
more runs of 0 ga...bigger batt under hood...bigger more batts in the back...big 3...more/bigger alt if can if it comes to it
Old 02-28-2011, 08:06 AM
Fly ty 215's Avatar
0/11 ssssss479
Originally Posted by 1ndatrunk View Post
I've been running dropping to the low 11s at idle/full tilt, and I want a rock solid electrical for demoing and basic safety of my equipment. Can you guyd provide me with some help in how to achieve that. This is a daily system only, no comps, just hard demoing.
Right now I run:
2 Audiopipe 3ks
2 Audiopipe 200.4s
4 Selenium 6s
2 SS Supertweets
220a alt
XS Power VCM
Well probably a diff batt upfront 2 or 3 more in the back and also I heard that those AP is very power hungry
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
could try adding at least 1 more run of wire. since you do have 2 big amps back there. along with that, another 2 or so deka's should do the job if you can fit them
-Youtube Channel
Old 02-28-2011, 08:09 AM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Ok, so if i get an XS D3400 in the front ( I was going to do that soon anyway), and another 2 runs of 1/0, would that help me out?
Yeah the AP3ks are a bit greedy, but in my 2yr experience, they are reliable
Old 02-28-2011, 08:14 AM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
I also thought of selling the APs and getting a single 5-7k amp. Would that make a difference?
Old 02-28-2011, 08:20 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Have you had any of the batteries load tested? Have you tried charging them with an external battery charger?
Give your batteries a good charge for a couple days on 2a trickle charge. Then see how the do.
Old 02-28-2011, 08:24 AM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
They were load tested a couple of weeks ago, and were fine, but I'll do it again if needed. With the car off, I stay at 13.1-13.2. Is that good?
Old 02-28-2011, 09:39 AM
Ja Marcus
0/11 sssss6975
Resting voltage is not always a sign of charge state. A battery will have a higher resting voltage shortly after running the vehicle but can fall up to .5v over the coarse of 12hrs.
Did you load test each battery individually or as a bank?
Old 02-28-2011, 10:22 AM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
separately. I didn't test the stock front batt, but it's only about a month old, and I plan to either get a shuriken or d3400 for the front this weekend.
how many runs of 0 awg would you suggest? Alex K General Car Audio Discussion & Questions 36 09-30-2010 10:25 PM
suggest me a obrien202 General Car Audio Discussion & Questions 11 05-17-2010 01:16 AM
what would you suggest gbo559 (Second Skin) 7 01-11-2010 04:27 PM
Suggest an amp Dyn0miteMat General Car Audio Discussion & Questions 10 07-26-2009 12:49 PM
Suggest me a 2k amp obrien202 General Car Audio Discussion & Questions 18 05-29-2009 02:22 PM
