what is a good battery to help push PB XA-3000d - Car Audio Classifieds!
Old 02-28-2011, 08:29 AM
slowloudnbangin's Avatar
0/11 sssssss65
Default what is a good battery to help push PB XA-3000d
So I just picked up a 9515g and a powerbass xa-3000d is on the way,
What kind/size battery would yall recommend to but in the back to help stabilize my voltage?
It's for a 08 trailblazer with stock electrical
Any suggestions appreciated
Old 02-28-2011, 08:56 AM
0/11 sssss1868
Well... that's a lot of power for stock electrical... especially when you factor in the extra power that will be needed down the line for a 4 channel amp so you can actually hear more than bass. An XSpower D3100 MIGHT handle it along with the big 3, and a matching XS battery under the hood. For cheaper options, check out Batteries - SLA Batteries - UPS batteries - GEL Batteries - AGM Batteries - Wheelchair Batteries - Scooter Batteries . A guy on another forum runs their batteries and is extremely satisfied with the performance, especially from the price point.
Old 02-28-2011, 10:08 AM
0/11 sssssss65
Well I wanted to maybe stick with Xs , kinetic or similar...... I just don't know which size to get
Old 02-28-2011, 12:45 PM
0/11 sssss1868
With XS, put the biggest XS battery you can fit under your hood, and another d3400 in back. That, along with the Big 3 upgrade, and you'll be set for 3k.
Old 02-28-2011, 09:04 PM
0/11 sssssss65
what about these?
Old 03-05-2011, 08:33 AM
0/11 sssssss65
if i go buy one of these batteries to day, what voltage should i look for if its going in to a stock trailblazer?
Old 03-05-2011, 10:05 AM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
For 3k you would need at least two of any of those + upgraded under the batt. And doing the big three. Or you could get a bigger alt and only need maybe one plus upgraded under the hood and big three. Either way a bigger alt would help
Old 03-05-2011, 11:32 AM
CLNFREAK's Avatar
0/11 sssss1788
Feedback Score: 23 reviews
I had c&d batts in my trunk... and they took a shit on me...
If you read the charging specs on thec&d... at 14.4 float charge your car will over charge them ...can't prove that is why mine lasted less then a year... AND if you run a big bank of them you might be ok.... me I would stay away from a single c&d... my ohio gen alt runs 14.4-15.0 dekas like 14.4 float
I would go Deka if you can't do xs power...
MAY 8 2009 ask me about that day !!!!
SUBS (2) 12" DC LVL 5
SUB AMP 1100.1
MIDS AND HIGHS AMPS 2 EXL 400.4
BATTS NSB group 31, XS power d3400
SINGER ALT 350 AMP
TEAM DC
DCSOUNDLAB.COM
SINGERALTERNATORS.COM
Need Help Choosing A Good Battery! brandonb1029 General Car Audio Discussion & Questions 19 09-20-2010 07:07 AM
good or bad idea to use this battery arntsmag General Car Audio Discussion & Questions 1 07-21-2010 10:02 PM
is this good for a battery?? mrbashful210 General Car Audio Discussion & Questions 7 04-21-2010 02:16 PM
Good amp to push my btl Dunbar91 General Car Audio Discussion & Questions 3 03-30-2010 12:58 AM
would this battery be good for car audio? Lsupaman General Car Audio Discussion & Questions 5 01-18-2009 10:51 PM
