Wiring Help - Car Audio Classifieds!
Old 02-28-2011, 02:05 PM
0/11 sssssss31
Default Wiring Help
Hi Guys,
Can I get some recommendations on how to wire my subs? I'd obviously like to wire them down to 1ohm, but can't find any diagrams how. Here are sub and amp specs:
Amp-Alphasonik PMA 1000DA:
1000 watts x 1 @ 4 ohm mono
1500 Watts x 1 @ 2 ohms Mono
2060 Watts x 1 @ 1 ohms Mono
Subs-Two 12" PSI
dual 1 ohm
1000w RMS
Old 02-28-2011, 02:06 PM
omgitscollin's Avatar
0/11 ssssss984
2 ohms IMO, idk your backup elec you might not be able to handle it w/o a H.O alt
Old 02-28-2011, 02:08 PM
0/11 sssss1330
Originally Posted by Skizza View Post
Hi Guys,
Subs-Two 12" PSI
dual 1 ohm
1000w RMS
Wire each sub in series to 2 ohm, then link the two in parallel.
Same thing as wiring two D2s to 2 ohm or two D4s to 4 ohm.
Old 02-28-2011, 02:28 PM
0/11 sssssss31
You mean like the diagram below correct? This will give me a 1 ohm load? Based on the specs, wiring them at 2 would under power them correct?
Old 02-28-2011, 02:36 PM
0/11 sssss1330
You can't wire two D1 subs to 2 ohm. I think that is correct
Old 02-28-2011, 02:39 PM
0/11 sssssss31
Ok, so you're saying the diagram above will give me 1 ohm
Old 02-28-2011, 02:45 PM
mtrevino92's Avatar
0/11 sssss1526
Feedback Score: 21 reviews
Hope this help:
http://www.the12volt.com/caraudio/wo...s.asp~Q~2~I~12
Old 02-28-2011, 02:47 PM
0/11 sssssss31
Originally Posted by mtrevino92 View Post
Cool thanks, been trying to get through to 12volt all day but kept timing out. I see however that the diagram for what I'm trying to achieve is the same as the one I posted, thanks for the confirmation!
Old 02-28-2011, 02:48 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
u can wire them to
.25, 1, or 4 ohms... those are ur options
parallel, series/parallel, series
TeamGG
Team D.O.A.
Old 02-28-2011, 02:51 PM
0/11 sssssss31
Originally Posted by Decaf View Post
u can wire them to
Wiring them at 1 ohm would sufficiently power them right, if we're talking 2060w mono dived by 2 = 1030w each to 1000w RMS subs.
help me out with wiring MERQUE Sound Quality Area 55 12-29-2010 10:08 AM
I need some wiring help. beany General Car Audio Discussion & Questions 29 06-09-2010 03:12 PM
wiring to this amp gbo559 General Car Audio Discussion & Questions 9 02-28-2010 02:25 AM
Wiring Help LOUDHOE General Car Audio Discussion & Questions 11 10-04-2009 10:02 PM
Sub Wiring Help dkhage1 General Car Audio Discussion & Questions 4 01-19-2009 09:22 PM
