Active mid/High Rca outputs - but you need to process mid/midrange/tweets??? - Car Audio Classifieds!
Old 02-28-2011, 07:14 PM
Magnet's Avatar
0/11 ssssss338
Lightbulb Active mid/High Rca outputs - but you need to process mid/midrange/tweets???
Just so I understand and buy the right parts the first time.
I am running a Pioneer premier deck active. What I dont get is how to do the crossovers/rcas for a 3 way setup on 2 sets of rca's.
I get that my sub obviously uses the sub rca, and my tweets amp is going to use the HIGH rca.
But how will I split my MID rca? And its crossover??
I want to run 2 sets of drivers off this rca, my midbass which will be seeing 80-2khz and my midrange which will be seeing say 200-6k
Would I set the mid rca crossover on the deck to 80-6000 and maybe use the amps to EQ high pass and low pass? Or would a passive crossover be best?
Just curious how you guys would do this.
Also, when you split an RCA output, how does it then know which is right side or left side
Appreciate the help!!!
Old 02-28-2011, 11:08 PM
SpeedEuphoria's Avatar
0/11 ssssss151
So you have 6 channels of amplification correct?
And your amps are active capable(band pass) correct?
Do you have passive x-overs?
Depending on if you have more than 1 amp and its x-over capabilities will determine which way you can set it up
I'm currently running 3 way off a non active HU and a 4chan bandpass amp, running the 6.5 active bandpassed, and the mid/tweet off the stock x-over on the other 2 chans
'03 Dodge Stratus Coupe
'89 Dodge Spirit soon to run 10's
Old 03-01-2011, 12:56 AM
0/11 sssss5305
You would need to split the mid RCA to both amps. 80-6000 on the HU and then a 2000 Fmod in line to the midbass amp.
You'd need to take a channel from BOTH split RCA's to maintain stereo separation...
Old 03-01-2011, 05:32 PM
Magnet's Avatar
0/11 ssssss338
I dont believe my amps do bandpass, its either high/flat or low setting must be selected
Im using 2 US Acoustic 4085's and a Kicker KX650.4
02-06 Altima custom kick panels and MB Quart PTK40 tweets, DLS UR2.5 midrange! nismos14 Car Audio Packages 2 01-25-2010 08:57 AM
new police force and election process korey_hofer Announcements - Suggestions - Feedback - Support 56 05-13-2009 03:34 PM
[COMPLEX] The Process of Powder Coating an Amp danteBirosel Tutorials & Quick References 1 11-12-2008 02:36 PM
