Proper way to hook Two D4 Subs to Saz-1500d - Car Audio Classifieds!
Old 03-01-2011, 01:24 PM
Jdubs04ss's Avatar
0/11 sssss1561
Default Proper way to hook Two D4 Subs to Saz-1500d
Hey just got my Sundown SAZ-1500d back from repair and I snuck out during work to go put it in and I got everything hooked up but since I was realll short on time and since there was 2 speaker inputs I was confused on whether each speaker hooks up in its own spot or if it needs to be bridges. I didnt know which wiring configuration would have gotten the impedence to 1 ohm.
-There are 2 subs wired to 2ohm each
-Each sub is a Dual 4 ohm wired in parallel down to 2 ohms
-Need to know which way to hook up/configure the wires for the amp to be running at 1ohm so I can get the most power
-Does 1 speaker have it's Pos/Neg wire plug into one side (right 2 terminals) and the other speaker plug into the other side(left 2 terminals)
-Or does each positive and each negative need to be twisted together and plug positive into left channel positive and negative into right channel negative?
I'm taking my lunch break soon and would love if someone could just tell me this real quick so I can get it bumping. I heard it bump a little but when my PR1.1000 memphis amp sounded like it bumps harder and it appears the gain is turned all the way up on my SAZ-1500d..Something doesn't seem right
2004 Impala SS
240amp Alt,XP3000s,BIG 3,1/0,Alpha Damp
Pioneer AVIC-X940BT
Digital Designs M3a(3 of them) & SAZ-2500d
18" Crossfire XS V.2 / 15" DC XL m2 D2
Need DC 270xp,320xp or bigger alt
Old 03-01-2011, 01:30 PM
0/11 sssss2030
Feedback Score: 22 reviews
Speaker 1 + to amp's first +, same speakers - to amp's first -, do the same for the other sub on the other 2 +- terminals, its a mono amp, it's bridged internally
Old 03-01-2011, 01:41 PM
0/11 sssssss44
im not far away from you. Id like to hear this soon if you dont mind.
By the way, just hook them both up normally. Positive to positive, negative to negative on the amp. If there were to only be one set of terminals you would just stick both positives together and negatives together. As the above poster said, they are paralleled internally so you can use both sets of terminals for ease of wiring.
Old 03-01-2011, 01:54 PM
bobbygilly's Avatar
Owner of UE
0/11 sssss6562
Feedback Score: 23 reviews
http://www.the12volt.com/caraudio/wo...2&I=42#results
Team Unlimited Excursion
get low or die trying....
Old 03-01-2011, 02:17 PM
Jdubs04ss's Avatar
0/11 sssss1561
Yea I think I did that and it didnt sound that much louder because I think one channel of my rca's isnt connected properley lol where are you at in Maryland?
2004 Impala SS
Pioneer AVIC-X940BT
Old 03-01-2011, 02:32 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
im in MD too man.lol. south calvert county though. and you can also just wire your two 2 ohm subs down to 1 ohm and just have one wire going into the amp if you'd like. in this case you can use eitther positive or negative unless otherwise specified
-Youtube Channel
Old 03-01-2011, 04:37 PM
Jdubs04ss's Avatar
0/11 sssss1561
Its about time MD's in tha house lol Their D4 subs btw..But also does anyone know what the amp rating is suppose to be on the SAZ-1500d V.1 not the v.2 because I remember seeing 40a X4 but I dont remember which version it was for because someone said somehting about them changing the fuse ratings on the amp and i dont know which one whey changed it on..right now my v.1 has 4 30amp fuses..is that right?
Sent from my DROID2 GLOBAL using Tapatalk
2004 Impala SS
Pioneer AVIC-X940BT
Old 03-03-2011, 04:34 PM
0/11 sssssss44
Im in Mt Airy. 40 minutes form rockville. Im from Germantown though.
Old 03-04-2011, 08:22 AM
Jdubs04ss's Avatar
0/11 sssss1561
Yup guys I wired it up and god damn this shit is loud lol..This saz-1500d put my old Memphis PR1.1000 to shame. No disrespect to Memphis because I still think they are an awesome car audio manufacturer and I use CM cast Mojo subs lol. Also a 1000 watt amp is no comparison to any 1500 watt amp but Sundown is now my new amp Im gonna be running with. It had 4 30 amp fuses and at a stop light with a heavy bass song it would sometimes drop to 11.4 volts so I put my volt booster back in, replaced the 30 amp fuses with 4x 25 amp fuses so it was only drawing 100 amps and it still hits ,for all I know, just as much as when it was pulling 120 amps. Once I get my new battery Im gonna put 4 40 amp fuses back in.
I know the amperage that the Sundown pulls depends on how ever big of fuses I put in. Is there a significant difference in the amount of watts put out by the amp from the amp having 100,120 or 160 amperage draw? Or does having different size fuses just pull more amps from my alternator and not really output more watts to the subs
But yea Id def be down with you checking them out..With my wife always making plans for me and not letting me do me since she feels that because she took of me during chemo that I should abide by her rules, Youd have to come down to either Rockville (355 from white flint to the courthouses) or anywhere on 28 from in the courthouses all the way to Quince Orchard like around the High School,Mcdonalds etc..Pretty much I work near white flint mall and I live off 28 right after Muddy Branch Rd and before Main Street/QO High School...We could meet up anytime between 5:30pm when I get off work to 7:00pm when I gotta be home to keep my girl satisfied lol
2004 Impala SS
Pioneer AVIC-X940BT
hook subs up to stock radio using RCAs? joshua Off Topic Chat 4 12-06-2010 10:13 PM
hook amp up to this?? joshua General Car Audio Discussion & Questions 23 06-01-2010 10:12 PM
How to hook up a Kinetik? Mr_Northstar_816 General Car Audio Discussion & Questions 8 02-22-2010 05:27 PM
Hook me up with 3-4 12 inch subs. kicker09kicker Wanting to Buy (WTB) 2 05-29-2009 04:47 PM
how to hook up equalizer tahoebrotha General Car Audio Discussion & Questions 2 11-19-2008 05:08 PM
