Audiopipe 30001d @ 1ohm daily? - Car Audio Classifieds!
Old 03-01-2011, 04:40 PM
0/11 sssss2148
Feedback Score: 26 reviews
Default Audiopipe 30001d @ 1ohm daily?
Ok, as most people know, this amp is rated at 2ohm final ohm load, (its 2 AP 1500D strapped in one amp case). What I want to know, would I be ok running it at 1ohm daily with a good electrical system?
Mechman 270amp alt, (1) 9A78DT up front, 2 or 3 Deka G31s in the rear, and (2) runs of Kolossus Fleks positive runs, (2) runs of Kolossus Flex to my chassis ground.
Would be pushing a pair of SA 15s in 6 cubic feet net @ 32hz, then later in my 4th order bandpass.
Old 03-01-2011, 04:44 PM
0/11 sssssss43
Mine would go into protect but I believe people have been able to do it
Old 03-01-2011, 04:45 PM
0/11 sssss8594
Feedback Score: 55 reviews
no...MUCH beefier electrical
Enclosures
Old 03-02-2011, 08:53 AM
0/11 sssss2148
Thanks for the info guys, guess this is a no go. Literally that's all the space I have ava for batteries and such, and it was just an idea I had.
Old 03-02-2011, 12:26 PM
813thumper's Avatar
0/11 sssss1116
ive seen many people do this with a good alt and 2-3 batts. i dont see why you wouldnt be able to pull it off. i have run the 3k and only running one channel at 1 ohm i only dropped to 13.5 with stock alt and 2 batts
I LIKE BUILDING ENCLOSURES FOR CUSTOMERS
Old 03-02-2011, 07:00 PM
Staralpha1's Avatar
0/11 sssssss83
1 ohm for burps and 2 ohms for daily use. This will be you best bet
2005 Scion Xb
Old 03-02-2011, 07:14 PM
0/11 sssssss76
Yes, but just because your battery only dropped to 13.5 volts doesn't mean it's good for the amp. Run a 30 watt amp at full clipping and your voltage won't drop below 14.3, still isn't good for the amp. My point is battery voltage isn't a good indicator of how good something is for the amp.
What kinda wattage would you wanna get out of it? You could *maybe* run it at 1 ohm if you don't run it full tilt.
Old 03-02-2011, 07:18 PM
0/11 ssssss884
i know i ran my ap1500s at .5 with no problem cant see why the 3000 wont do 1 ohm.
Old 03-02-2011, 07:22 PM
0/11 sssss1380
I ran one at one ohm on 3 optima redtops and 160a alt daily no problems try it, worse case it goes into protect
youll be fine...
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
1200A of singer power
12 Fi SSDs fully loaded
[email protected]
Old 03-02-2011, 07:24 PM
Farmacist's Avatar
0/11 ssssss145
because the ap3k is already strapped internally
Ive seen the 3ks ran at 1 but you need to have very good ventilation and reserve power.. even then I've seen them go poof
[SOLD] audiopipe 30001d remi_357 Mono Amplifiers 23 12-29-2010 09:17 PM
[SOLD]FS: Audiopipe AP-30001D Beatdown337 2-Channel Amplifiers 13 01-31-2010 12:35 PM
Audiopipe AP-30001D Bigpimpin91 CACO Amp Internals 1 12-24-2009 05:05 PM
[sold] Audiopipe 30001d Bobby32 2-Channel Amplifiers 1 10-14-2009 09:56 AM
