did i damage my crossover? - Car Audio Classifieds!
Old 03-02-2011, 02:47 PM
MERQUE's Avatar
0/11 ssssss622
Default did i damage my crossover?
ok i have a set of components installed. they are infinity kappas.
if i measure the impedance of the tweeter by itself it reads 2.3 ohms. the 6.5 by itself also measures 2.3 ohm.
when i have everything wired up and i measure the impedances at the crossover, the input to the crossover reads 2.3 ohms, the 6.5 output also reads 2.3 ohms at the crossover, BUT when i go to measure the tweeter output the dmm reads like .5 ohms. is it damaged?
i think i remember measuring everything before i installed everything and both tweeter output and 6.5 outputs and crossover input measured 2.3 ohms but im not sure.
could someone check they're impedences at the crossover for me?
Old 03-02-2011, 06:19 PM
Sonically_Sound's Avatar
http://www.betherave.com
0/11 sssss2125
Each brand crossover is going to be different so unless someone has the kappa set you have their measurement is useless.
Did you do something specifically that makes you think you messed them up? If your speakers sound fine off them I wouldn't worry about it.
Social:
Old 03-02-2011, 06:27 PM
MERQUE's Avatar
0/11 ssssss622
i think i remember measuring them and it read 2.3 ohms, the same as the tweeters.
when i was wiring up my amp i was setting gain by ear because i did not have a test tone. i ended up turning the gain to its max trying to listen for distortion. after that they didnt sound the same.
Old 03-05-2011, 07:37 PM
MERQUE's Avatar
0/11 ssssss622
anybody here have kappas also?
Old 03-05-2011, 08:42 PM
0/11 sssss2125
You could have hurt the crossover, amp or the speaker.
When you set the gain by ear the easiest way is to get your equalizer, bass boost etc. turned all the way off. Turn your gain all the way down. Turn your head unit all the way up or around 3/4 depending on the interval size you want for each notch in sound. Then turn the gain up to where the speakers start sounding stressed. Turn the gain a little below where they sounded stressed, especially if you are going to tweak the sound after.
Social:
Old 03-05-2011, 11:16 PM
Resistance is frequency dependent. The crossover will modify the resistance to allow a certain amount of current (power) to pass to each speaker depending on the frequency. The DMM will read resistance at a set frequency.
In short, your crossover is probably fine.
Old 03-06-2011, 07:41 AM
MERQUE's Avatar
0/11 ssssss622
i mean with no power going through it. stereo off.
Old 03-06-2011, 09:09 AM
What readings do you get when you do the same test at the crossover but with no speakers connected (no power)?
Old 03-06-2011, 08:51 PM
MERQUE's Avatar
0/11 ssssss622
im gonna check that tomorrow. is there any way to check the crossover to see if its damaged?
Old 03-06-2011, 09:02 PM
18inchjeepin's Avatar
0/11 sssss1931
Feedback Score: 37 reviews
the crossover output should little to no resistance, all it is is a sound filter, only the speakers have resistance
Silver HHR
TEAM SOUNDSTREAM
XS Power D3100 with Toolmaker blocks
Alpine 9884-> Soundstream RUB4.600-> Soundstream SST-05 tweets-> Soundstream 804N 8" neo mids
A-pipe mini 1500-> pair Sundown SA15's -> 4th order wall
sun damage to subs dgiveans10 General Car Audio Discussion & Questions 2 09-08-2010 10:18 AM
Mojo Damage krimro General Car Audio Discussion & Questions 20 04-18-2010 09:41 PM
amp damage gjnelson General Car Audio Discussion & Questions 10 04-21-2009 10:09 AM
Catastrophic damage SPY General Car Audio Discussion & Questions 19 02-15-2009 11:51 AM
Crossover Lesson (is your passive crossover labeled correctly?) iamsonic Tutorials & Quick References 0 01-20-2009 07:05 PM
