lil problem, bit of help needed - Car Audio Classifieds!
Old 03-02-2011, 09:30 PM
0/11 sssssss95
Default lil problem, bit of help needed
hey fellas, hows it goin. I got a bit of a problem. My amp plays fine then after a while it cuts out, led blinks red showing a short code. I checked my power wire and theres no open spots in in touching the chassis or cab to short. I'm wondering if a semi shoddy ground can cause this, i sanded my mounting point for the ground im just kinda at my end with this. anyone have any suggestions?
Old 03-02-2011, 09:32 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
doesnt just mean its a short. its the amps protect circuit. it could be low voltage, low impedance, among simply heating issues. tell us more about the setup
-Youtube Channel
Old 03-02-2011, 10:23 PM
0/11 sssssss95
its an arc audio kar series 300.2. i have it mono running two ten inch 4 ohm dvc memphis subs. Its not getting too warm to the touch, if any amount of warm at all. You mentioned low voltage, well my volt meter does drop down to 12.0 volts. I also have an electric fan setup that draws alot of amps on my truck.. Before i hooked the amp up i usually see 14.0 volts cold, but it would drop to 12 volts or so when fans would come on.. i think i have my speakers wire up correctly i mean each sub has two coils, i have the coil in the rear of the sub wired with a jumper from positive to negative, then the other coil side is run to 1 channel of the amp, same on the other sub, they are both wired to one channel of the amp i am assuming i have a 4ohm final load in mono..
Old 03-02-2011, 10:28 PM
0/11 sssssss95
i have a new high output alternator coming its a 250 amp, hopefully if it is low voltage that thing will help over the stock one...
Old 03-02-2011, 10:34 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
If its just low voltage going to your amp then you should have just gotten a smallish extra battery rather than buying a big alternator unless you plan on running a bigger amp
Old 03-02-2011, 10:37 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
how big is the batt/s?
did you do the big 3?
how big is your power wire?
who wants a nudel ride?
Old 03-02-2011, 10:48 PM
0/11 sssssss95
i have another amp waiting to be installed, my battery well its a stock replacement from autozone, plan on upgrading that as well. i havent done the big 3 either. my power wire is 1/0 awg ran to a dis block and then from there its 4 ga.. I know those electric fans i put on my truck pull alot of amps on initial start i heard close to 80 amps.. It sounds damn good while its bumpin though, good for memphis shallow mount 10's. I just wanna keep it playin...
Old 03-02-2011, 11:07 PM
0/11 sssssss95
any of you fellas got any recomendations?
Old 03-03-2011, 01:32 PM
0/11 sssssss95
i appreciate your help guys after further re eval of my speaker wiring i found out i had accidently wired it as a 2 ohm load and needed 4 ohm load.. Shes working like a charm now.. thanks for re iterating for me to look that over.. the amp only went into protect 2 times while i was running it for a total of probably 30 mins, so i hope alls well and i didnt wreck anything from that 30 mins...
Old 03-03-2011, 01:51 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
You couldn't have wired it to 2 ohm, it's either 4 ohm, 1 ohm, or 16 ohm with dvc4's.
My Car, My Ears.
HO alt needed + wire advice needed AllenH427 General Car Audio Discussion & Questions 25 11-08-2010 10:04 AM
problem with 3kwp [Problem Solved] jizazz12 (Crescendo) 10 04-30-2010 06:46 AM
BIG 3 needed? dylan9999 General Car Audio Discussion & Questions 7 04-26-2010 09:38 AM
needed 4kw+ tankglh21 Wanting to Buy (WTB) 18 09-05-2009 01:28 AM
8k amp needed slammed636 Wanting to Buy (WTB) 10 05-05-2009 02:11 AM
