Steve's Paint, Electrical Design Possibility. - Car Audio Classifieds!
Old 03-02-2011, 10:45 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
Default Steve's Paint, Electrical Design Possibility.
Got all my electrical supplied picked out. XS d3100 on the way, waiting to hear back from DC on the alternator. 4/0 welding wire. Now, how to put all of this shit together. I had another user help me answer this, but I thought I would widen the knowledge base. So I am looking at wiring, and just curious about different wiring styles. This is an idea I recieved from a guy on here I assume knows what he is talking about.
"I still use the factory grounds. I simply give the auxiliary system a better means of conveying the energy.
In a perfect world, that system would be in addition to the factory system
2nd alternator and batteries just for the stereo.
In my truck I only intend to have one alternator. so the original system will be connected to it also.
the engine block needs it's ground for the starter, EFI system, sensors and other things which run off of it. So the engine block to body connection still needs to be there.
The battery ground to the body needs to be there also for the computer and dash and everything to work.
I simply add the upgrade wiring to do the job it's intended for. factory wiring can remain intact including the factory alternator power wires.
my drawing only depicts the 1/0 circuit."
This makes perfect sense, but does the option to ground my aux wire from alternator mount to battery (-) have advantages? As opposed to just using the "Big 3" style upgrade?
Now this is the idea that I had.
I have questions about these. 2 major differences I see is that the first has no ground directly from the battery. Are there pros/cons to this? Does it just ground directly from the alternator's connection to the engine block instead of taking a trip from the battery (-), to the block, to the alternator? So instead of making a ground AND a connection to the engine block, you just combine then directly and run the wire directly to the alternator engine block connection? What do you guys think?
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 03-02-2011, 10:57 PM
0/11 sssss3784
Here is another question for the community pool. Which orange stars would you fuse? I would think to be as safe as possible, all of them to protect all the equipment, but what do you guys think?
empty trunk
DC Power 270xp
.... so far
Old 03-03-2011, 03:59 PM
0/11 sssss3784
Noone wants to play with paint??
What do you guys think about Hooker power wire for running the 2.5 feet or so from the batteries to the amp? Think it would make difference from something like Knu OFC?
empty trunk
DC Power 270xp
.... so far
Old 03-03-2011, 06:51 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Steve. Figure 1 is the best bet. Grounding to the alt case is the best place. So if you do that a block ground isn't necessary. From there one run of each front to back will be sufficient. As for the back battery to amp you want the most current flow possible. That is were I would concentrate most of you attention to getting as much current to the amp as possible. Weather its multiple runs to a block that toolmaker makes or several wires into one connection.
Steve's Malibu Build Log BassikInstincts Build Logs 335 08-16-2015 05:42 PM
Steve's Box Design BassikInstincts Enclosure Discussion & Design Construction Help 40 02-28-2011 05:49 PM
the possibility of my next system Highs On Bass General Car Audio Discussion & Questions 71 05-06-2010 10:08 AM
Steve's Tahoe- PCA designed and installed pulsecaraudio Team Pulse Car Audio 3 02-13-2010 08:40 PM
chaos, defined; infinite possibility Nudels New Member Orientation 18 05-15-2009 04:36 PM
