subwoofer builders! question - Car Audio Classifieds!
Old 03-03-2011, 01:42 AM
e2theloc's Avatar
0/11 ssssss909
Question subwoofer builders! question
what size bolts hold the basket to the motor? and do you guys glue the basket to the motor too?
150+ Club
Follow me on Twitter!! @e2theloc
Old 03-03-2011, 01:44 AM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
I think this exact same q was asked before.
Glue is nice to add over tightened bolts.
Old 03-03-2011, 01:46 AM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Depends on the motor, M6 is pretty common, TC uses 1/4"-20.
/ CAAA Member #2 /
Old 03-03-2011, 01:53 AM
Novicaine's Avatar
0/11 sssss6135
I believe m6 20 is the common one.
Old 03-03-2011, 02:01 AM
e2theloc's Avatar
0/11 ssssss909
i know to put epoxy glue on the bolts, but what about wetween the basket and motor. im thinking yes. what size bolts? i need a set
150+ Club
Old 03-03-2011, 02:06 AM
omgitscollin's Avatar
0/11 ssssss984
SD used some spacer between it
Old 03-03-2011, 02:35 AM
0/11 sssss5305
I use a little permatex gasket maker between the motor/basket. Also red threadlocker eliminates the need for exopy on the screw/bolt heads.
Old 03-03-2011, 02:40 AM
I uses silicone on motor/basket seam and for the screw
I don't recommend using the factory screws or ca gluing them in if you need to take basket off it really really sucks getting them off
I'd use allen head machine screws I have them in my sub and lover them
Old 03-03-2011, 03:05 AM
Violence*'s Avatar
OCD Member
0/11 sssss7568
Feedback Score: 41 reviews
allen head screw or regular hex head bolt is what i use. take the motor to the hardware store and buy the correct bolts. i do it all the time.
CA glue the basket to the top plate. put a dot on the head to keep it form backing out. DO NOT get CA glue in the threads. you will be screwed.
Old 03-03-2011, 12:04 PM
e2theloc's Avatar
0/11 ssssss909
ok, im going to take the motor to the hardware store. thanks guys for the help
150+ Club
Experienced box builders question Boomintahoe Enclosure Discussion & Design Construction Help 7 10-15-2010 08:48 PM
Well i got a question about a subwoofer! mattintc10 General Car Audio Discussion & Questions 20 08-09-2010 07:37 AM
Custom subwoofer question DonH (PSI Car Audio) 7 02-20-2010 02:14 PM
quick H/T subwoofer question SLOWnSTEADY General Home Audio/Video 19 10-22-2009 01:41 PM
Subwoofer question MHD2000 General Car Audio Discussion & Questions 7 05-29-2009 04:31 PM
