aeroport question - Car Audio Classifieds!
Old 03-03-2011, 03:23 PM
0/11 ssssss532
Default aeroport question
What is the general rule on port area per cubic foot with an aeroport?
Old 03-04-2011, 10:22 PM
Beatdown337's Avatar
0/11 sssss1535
bump for this question as i was wondering the same thing
Old 03-04-2011, 10:33 PM
0/11 ssssss368
12sq in per cu. if I remember correctly. But don't quote me
[SIGPIC][/SIGPIC]
2001 Ford expedition
New build coming soon!
Lots of cone area and lots of power
Old 03-04-2011, 10:51 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Just use a PA calculator for your particular sub. Your subs xmax, and diameter are 2 of the determinents of it. 12 sounds good per cube though. Use some aero ends for sure.
Old 03-04-2011, 11:01 PM
0/11 sssss1535
i thought 12 per was for slots? Or is it the same?
Old 03-04-2011, 11:08 PM
0/11 sssssss44
12-16 per cube for slots, aeros are more efficient so you can use less.
Old 03-04-2011, 11:10 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
I usually try to stay above 9 sq inches of port per cube when using aero ports.
Louder. Lower.
Team Tupperware
Old 03-04-2011, 11:11 PM
Novicaine's Avatar
0/11 sssss6135
Aeros are very smooth flowing so they allow you have a higher velocity and not cause as much friction. This isn't to say that a "slot" cannot be built nice enough though to compare. For what will even fit in a vehicle, you can never have too much PA. If it ain't big enough it will have a ceiling effect with power to SPL aswell.
Question about Aeroport length & tuning.. RapidAutoQuotes General Car Audio Discussion & Questions 4 02-02-2011 11:00 PM
a lil aeroport help jmkanek Enclosure Discussion & Design Construction Help 3 09-11-2010 04:46 AM
Need help with aeroport plz Zooook Enclosure Discussion & Design Construction Help 11 06-19-2010 08:21 PM
Aeroport question resko1 Enclosure Discussion & Design Construction Help 8 11-19-2009 10:38 PM
aeroport question RidnClean General Car Audio Discussion & Questions 9 04-17-2009 08:16 PM
