termlab comparison - Car Audio Classifieds!
Old 03-03-2011, 06:27 PM
0/11 ssssss532
Default termlab comparison
Has anyone noticed a difference in scores from a usb and non-usb termlab. I bought a used non-usb termlab and the scores i'm getting seem higher then i expected. I'm not complaining if I'm getting correct numbers I just don't want to get to a comp and be disappointed because my score is off.
Old 03-28-2011, 08:05 AM
Carolina's Trunk King!
0/11 ssssss557
check your k factor setting
Old 03-28-2011, 08:30 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Check your CAT 5 cord. That can give false readings if damaged. There is only a couple tents between my meter and the judges meter at the events I attend.
Old 03-28-2011, 09:23 AM
TNJ
0/11 sssss7882
also the meter is used. it could be reading higher because of that fact as well. used meters read higher.
Old 03-28-2011, 09:26 AM
Ja Marcus
0/11 sssss6975
My meter is quit old and still reads within tolerance of original specs. Check your programing for the K factr setup and check the CAT 5 cord. I had the same issue and it ended up being the cord was bad from being slammed in a door so many times.
I would try that first.
Old 03-28-2011, 09:31 AM
0/11 sssss1250
Feedback Score: 34 reviews
Meters will read differently slightly.
SPL-Lab REP
Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has more features and more support? PM me.
W7 vs ICON comparison Nemesis4895 General Car Audio Discussion & Questions 30 10-17-2010 09:34 AM
Wire Comparison 92K1500 (Shok Ind) 3 10-10-2010 06:42 PM
Sonance vs. z15 Comparison jd93kid General Car Audio Discussion & Questions 0 09-20-2010 03:30 PM
comparison montr2229 (PSI Car Audio) 8 06-16-2010 03:17 PM
wire comparison Memphistahoe02 General Car Audio Discussion & Questions 25 02-08-2010 01:31 PM
