AQ2200d issue - Car Audio Classifieds!
Old 03-05-2011, 06:29 AM
Rogers's Avatar
0/11 ssssss346
Default AQ2200d issue
so i was riding around the other day with the volume down low and i noticed everytime i hit a bump my woofers thump a little... so i started investigating... if i jiggle the rca inputs on the amp the woofers bump or pulse a little... im guessing that the vibrations knocked a solder joint loose or something in the input section... the amp still plays fine, but i havent turned it on since i heard it start messing up... i figure why take the chance of damaging something else in the amp making the repair bill that much more.. anyways, im going to pull the amp out today and take a look at it... anyone else had this problem?
93 Saturn SC2
4 Sundown SA-15's walled
2 CV Stroker S2000.1's, CV Vega V400.4
All old school Kicker Highs
Powered by Kinetik
Old 03-05-2011, 06:33 AM
0/11 sssss2298
Feedback Score: 54 reviews
Had something like this with my old directed amp. I had it on the box and I vibrated the solder joint loose on the RCA's inside the amp, not saying thats your issue but you never know.
Old 03-05-2011, 06:42 AM
Rogers's Avatar
0/11 ssssss346
im guessing this is what happened... my amps are mounted on an amp rack but the amp rack is mounted to the back of the enclosure... it really didnt seem like it was vibrating that much but you never know...
93 Saturn SC2
Powered by Kinetik
Old 03-05-2011, 06:45 AM
Rogers's Avatar
0/11 ssssss346
93 Saturn SC2
Powered by Kinetik
Old 03-05-2011, 07:04 AM
dat517boi's Avatar
0/11 ssssss834
my RCA on my AQ2200 is loose i actually need to email DJ about the issue.
Vehicle: 2000 Jeep Grand Cherokee
Head Unit: JVC KD-R210
Sub: SA Nightshade V.1 18 x2
Sub Amp: Audioque AQ2200 x2
Battery: Optima Yellow Top, 9A31 x2
Alternator: 235 amp alt
can we start the bidding war for the sister and mom?? and can we get T/S parameters on both?
well unfortunately the t/s when they were new will be way diff now.... these drivers are used and beat on pretty hard in there day (not personal use but ive known all the owners and theres been alot)
aq2200d Kyle K (db-r) 1 12-25-2010 09:45 PM
aq2200d at 2 ohm? Vince6o1 General Car Audio Discussion & Questions 11 10-29-2010 01:16 PM
aq2200d Kyle K Mono Amplifiers 2 01-27-2010 01:20 AM
aq2200d SUB BASS JUNKIE General Car Audio Discussion & Questions 8 12-28-2009 10:42 PM
WTB AQ2200d Camshoc Wanting to Buy (WTB) 1 11-10-2009 09:33 PM
