Amp gettin hot!! - Car Audio Classifieds!
Old 03-05-2011, 11:47 AM
0/11 sssssss88
Default Amp gettin hot!!
I have a 4 channel amp that is 4 x 100 at 4 ohms, 4 x 200 at 2 ohms, and 400 x 2 bridged at 4ohms. I was running the amp at 4 x100 watts at 4 ohm, but i wanted to make my speakers louder, so i recently put in 2 8 ohm mids and have them bridged together to make them at 4 ohms taking 400 watts or 200 for each speaker. And for some reason my amp will get really hot after about an hour, when i was running the 4 speakers at 100 watts each, it would never get hot for a while. Is the efficiency so much lower being bridged that it heats up the amp this quick or is something else wrong thats making the amp real hot real quick.
Old 03-05-2011, 11:50 AM
bobbygilly's Avatar
Owner of UE
0/11 sssss6562
Feedback Score: 23 reviews
how hot are we talking...some amps run better when warmed up
Team Unlimited Excursion
get low or die trying....
Old 03-05-2011, 11:53 AM
1loudyukonxl's Avatar
0/11 sssss1569
Most 8 ohm speakers are not 8 ohm my o2s that are rated 8ohm are 5.7 so finall load of 2.85 ohms could cause that but generally class ab amps get hot
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 03-05-2011, 11:56 AM
0/11 sssss1330
Running the amp is bridged mode is like running each channel at 2 ohm. This will cause it to run hot.
Old 03-05-2011, 11:57 AM
0/11 ssss31258
what brand and model is the amplifier?
Old 03-05-2011, 12:04 PM
0/11 sssssss88
the amp is a hifonics Hfi 100.4, if i got another amp maybe a dc or sundown 4 channel, you think it would still heat up just as quick
Old 03-05-2011, 01:04 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
You may be clipping the signal. Are the subs bridged on only 1 channel or 2?
Old 03-05-2011, 01:07 PM
Eric B's Avatar
LowBlowBro
0/11 sssss2140
Beings class AB amps are generally 50%-60% efficient and the rest is heat, Id say its the heat sink doing its job. Especially if your running the amp at its "limit"
Old 03-05-2011, 01:16 PM
813thumper's Avatar
0/11 sssss1116
yeah class A/B amps run hot at 2 ohms.
I LIKE BUILDING ENCLOSURES FOR CUSTOMERS
Old 03-05-2011, 01:22 PM
Ja Marcus
0/11 sssss6975
How do you get 400watts divide into the two paralleled 8 ohm? They can only be bridged on two of the four channels giving you [email protected] ohm. So 100 watts a piece.
How are they wired at the amp?
Just gettin really into audio nateski10 New Member Orientation 16 03-01-2011 06:43 PM
Gettin a TC LMS-R 12", what amp? Xxiv0 General Car Audio Discussion & Questions 0 01-25-2011 04:08 PM
Boswell's Metro gettin down... pulsecaraudio Car Audio Videos 4 01-22-2010 02:38 PM
gettin ready peas247 General Car Audio Discussion & Questions 22 01-17-2010 07:42 PM
Gettin Dat Overtime! 92K1500 Off Topic Chat 6 05-10-2009 02:53 PM
