Car Audio Classifieds
Go Back   Car Audio Classifieds > Car Audio Help & Discussion > General Car Audio Discussion & Questions
Old 05-03-2011, 10:37 AM
AR-15's Avatar
0/11 ssssss866
Default How to set up this amp?
This is the most confusing crossover set up I have ever seen....How in the hell would you set thios up for 4 Polk Audio DB57i? I want it to be hP @ 80-100hz
Soundstream RUB4.500
Old 05-03-2011, 10:42 AM
audioarsonal's Avatar
Ja Marcus
2/11 sssss6750
That is no different then any other 4 channel Set the switch to HPF for all 4 channels. Then dial in the knob to your XO point you want. Adjust gain to suit....
BlackWaterOp's Avatar
Super Moderators
1/11 sssss4386
Feedback Score: 33 reviews
Are you wiring all 4 polks to each channel separately? If so, the top and bottom would be set to HP and set them up identically as far as gain and X-over.
eBay (douglas.leejr) 475+ Feedback 100% Positive
PayPal Premier Verified Since 2004 (
E-thug:
Originally Posted by Patrick
If u dont wanna be here i can make sure u get the banhamma
lets keep it as simple as that.
Old 05-03-2011, 10:46 AM
AR-15's Avatar
0/11 ssssss866
there is more than just a HPF switch, theres one that says LP/HP freq, then a seperate HP, and then a switch that says low pass 50-800hz and 250hz-4khz.
Old 05-03-2011, 10:49 AM
AR-15's Avatar
0/11 ssssss866
yes each seperately, i hear your by setting them up identically but the crossover pots on the top and bottom arent the same range. owners manual might as well be used for TP
Old 05-03-2011, 10:53 AM
Old skool junkie's Avatar
DTD
0/11 ssssss715
Feedback Score: 22 reviews
And then set gains accordingly, and of course "fine tune" my suggestions as needed (xover freq)
SQL?? One or the other folks, make up your mind already!
Don: Surfer, you are a really well known SPL box builder - how do you make a box sound REALLY loud?
Surfer: You taketh the cardboard paper towel roll, you cutteth said roll longways, you tapeth said cardboard to the boxeth.
The Following User Says Thank You to Old skool junkie For This Useful Post:
AR-15 (05-03-2011)
Old 05-03-2011, 10:55 AM
Ja Marcus
2/11 sssss6750
Both do the same thing. They are just set up to be able to run 2 channels for highs and 2 for bass if needed. In your case both switches would be on HPF. the XO won't be turned to the same place but both can be XO'd at 80hz. The bass boost to the right should both be off and the other switch won't be used since you aren't running it in LPF.
That only leaves the gain knob to adjust.
The Following User Says Thank You to audioarsonal For This Useful Post:
AR-15 (05-03-2011)
Old 05-03-2011, 10:56 AM
Ja Marcus
2/11 sssss6750
He cannot set both filters to 1/4 turn as they are not the same filters. The bottom one will get turned more like 1/2 way and the top maybe 1/4.
AR-15 (05-03-2011)
Old 05-03-2011, 10:57 AM
AR-15's Avatar
0/11 ssssss866
like this?
Old 05-03-2011, 11:20 AM
Ja Marcus
2/11 sssss6750
You got it. We cannot tell you the exact position on the XO. You will have to experiment and see what works. But that gives you a general idea of location they should be in.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Guest
