possible to use deck power for rca's? - Car Audio Classifieds!
Old 07-23-2011, 02:31 AM
0/11 ssssss364
Default possible to use deck power for rca's?
what im asking is it possible to use the left and right + and - and wire it up to rcas? the reason im asking is because the output for my rcas on my deck are messed up and i dont have the $ for a new one . btw its going from the deck to the eq right below it . thx.
Old 07-23-2011, 04:07 AM
You can use a line-level converter. You can not use the high level speaker outputs as a substitute for the low-level RCA signal.
Old 07-23-2011, 01:14 PM
0/11 ssssss364
i have one and i wired it up and it worked for a few days and then it stopped. tried rewiring it and it just make a high pitch noise when i plug the rca's in . but my eq works perfect . if i use an headphone jack to rca adapter and plug an ipod into my eq it sounds perfect.
Old 07-23-2011, 01:16 PM
3rdshiftdiscretion's Avatar
CACO Late Night Crew
0/11 sssss4240
Feedback Score: 30 reviews
High/Low converter?
Bewbs
Old 07-23-2011, 02:52 PM
0/11 ssssss364
ya but i guess it burned out.
Old 07-23-2011, 03:37 PM
I sounds like something is using the RCA shield as a ground. Check your grounds before you fry anything else.
Old 07-23-2011, 04:07 PM
0/11 ssssss364
for what? my amps? hu? eq?
FS: power/ground wiring, RCA's, speaker wire, Breaker-Stinger, Fosgate Goindef154 Wiring, Electrical & Other Installation Equipment 16 08-05-2011 11:44 AM
stinger 16g for power for deck? smokenyall General Car Audio Discussion & Questions 7 07-06-2011 02:58 PM
power,ground, and rca's bottlefed1 General Car Audio Discussion & Questions 3 02-14-2011 10:35 AM
[FOUND] Looking for Deck, 6.5" component set, and 2ch amp to power them TeamPSI Wanting to Buy (WTB) 8 07-30-2009 11:31 AM
My monster cable RCA's for your power cap. What you got? tahoebrotha Car Audio Trader (WTT) 3 11-19-2008 09:12 PM
