Help me figure out my current draw.. - Car Audio Classifieds!
Old 07-23-2011, 07:27 AM
gcguy2169's Avatar
0/11 ssssss174
Default Help me figure out my current draw..
I'm going to be running a AQ HDC310 with a powerbass XA-1500D. It's got 3-40 amp fuses. Is this enough information to figure out how many amp's i'll be drawing from my alt?
2009 Malibu LTZ - Silver
2 Audioque HDC312's, Autotek Mean Machine 3000.1, All Crescendo Audio mids and tweets. PW6's and FT1's
BOUGHT FROM: nutxo, stills
Old 07-23-2011, 07:40 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
With a little more info you can make an educated guess. ie voltage ohm load
But music is transient so that number will not be a constant.
Old 07-23-2011, 08:09 AM
gcguy2169's Avatar
0/11 ssssss174
well...im not going to crank the amp max gains or pop the fuses, but im assuming the MAX draw before the fuses go are going is going to be 120 amps. I know with different music and what-not, punches in music, etc, will have different draw. However there has to a happy medium somewhere. 80 amp draw off 1500 watts? Someone has had to done this before.
Old 07-23-2011, 08:53 AM
0/11 sssss1237
well depending on your alternator amperage, and what RPM it will produce different amperages at different Rpms
Old 07-23-2011, 08:55 AM
gcguy2169's Avatar
0/11 ssssss174
Amperage is not an issue. I've got 170 at idle.
Old 07-23-2011, 10:35 AM
Ja Marcus
0/11 sssss6975
Its hard to say. Impeadance rise plays a roll. Which is dependent on several factors. But yes you could just add up all the fusing and use that as a rough estimate. Also remember the alt runs the vehicle as well. So some current must be factored into it in the equation.
Old 07-23-2011, 12:34 PM
gcguy2169's Avatar
0/11 ssssss174
ok well I've got 270 amps to play with. 80 for the vehicle, but is there a mathematical way to observe this? I.E. using a multimeter to measure at the amp while playing something bass heavy so I get an Idea of the draw? I know there is I jsut don't remember how to properly test that.
Old 07-23-2011, 12:40 PM
csu87's Avatar
Louder then him^
0/11 sssss2525
Feedback Score: 22 reviews
you can use a dc clamp meter and it will tell you the amperage your amp is pulling. or you can estimate by:
(Watts/Voltage)* Efficiency = Amps
(1500/14) * 1.2 = 128.5
using 1.2 because average efficiency of class d amps is ~80%. Now if you voltage isnt 14, then you are going to draw more current. Also remember this is the most basic way to figure out your current draw and it doesnt take into effect alot of factors like voltage drop, wire resistance ...
Current 09 BMW 335xi: SQ build with Sundown and IA in progress
Retired '99 Jimmy: Highest TL 155.1 w/ 2 self made 12s and AQ3500.1
Old 07-23-2011, 12:42 PM
gcguy2169's Avatar
0/11 ssssss174
That's what I'm looking for! Thanks man...I'd rather have a rough idea than none.
Old 07-23-2011, 12:43 PM
gcguy2169's Avatar
0/11 ssssss174
but wait, hows 1.2 relate to 80%? educate me more on that..
Gain vs Speaker impedance and current draw Dammed General Car Audio Discussion & Questions 6 06-17-2011 08:47 AM
Current Draw of Average Headunit? taylorpro General Car Audio Discussion & Questions 5 11-23-2010 05:04 PM
Can you draw? 420guy Off Topic Chat 19 12-02-2009 11:24 PM
500/1 and 300/2 Current Draw ClevelandFreeman General Car Audio Discussion & Questions 11 11-09-2009 09:15 AM
How to find current draw of amp. forceww Tutorials & Quick References 2 08-10-2008 03:29 PM
