Eclipse AVN52D installation - Car Audio Classifieds!
Old 07-23-2011, 09:35 AM
thawaxshop's Avatar
0/11 sssss2506
Feedback Score: 48 reviews
Default Eclipse AVN52D installation
Never done a nav unit and from reading i have a pretty good idea on it, few questions though.....
I have some wires i NEVER had to hook up before so idk how to go about all this.
1)Vehicle speed pulse signal wire
2)Reverse signal wire.
Idk if i NEED these hooked up for the unit to function or if they can be left out.
Also anything special with the parking brake bypass (like pioneer and most newer ones that need a relay or something) or is it old school and jut ground it.
Old 07-23-2011, 11:12 AM
jhughes's Avatar
0/11 ssssss185
You shouldn't need the reverse signal wire connected unless you are using a back-up camera.
Pulse speed wire, no idea.
I believe you just ground the brake bypass on eclipse units. Look in the manual and see if the parking brake simply has to be set for it work, if so, just ground it. If you have to do a series of actions to get it to work, you may need a PAC module. Good luck!!.
//\\ New Project:
Eclipse AVN52D jhughes Head Units, Processors & EQs 26 07-18-2011 12:00 PM
batt installation ? thel.t.d.supply General Car Audio Discussion & Questions 13 01-31-2011 10:11 AM
rca installation? KickerCobalt General Car Audio Discussion & Questions 14 10-25-2010 02:55 AM
AQ HDC3 15''. installation help jgutierrez General Car Audio Discussion & Questions 8 09-06-2010 02:26 PM
[SOLD] installation guys/shop owners - Installation accessories! Old skool junkie Wiring, Electrical & Other Installation Equipment 3 06-30-2010 11:28 AM
