alternator on its way out? - Car Audio Classifieds!
Old 07-23-2011, 06:15 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
Default alternator on its way out?
alright i have a Motor City Reman 170 amp alternator on my car and up until today all was good. before today, it would always idle at 14.4+ volts as long as no load was on the car electrically. and if i was driving around 2k, at full tilt, i would NEVER drop below 14. today, i went to lunch and noticed it was idling at 13.7 ish. i gave it gas and as i did it went up like normal to 14.4. however, the lower the rpms came down, the voltage steadily came back down to 13.6 ish as well. now i thought the battery just might have been drained during a demo sesh, or it was just cause it was hot as shit earlier, but its cooler now and its still doing the same thing. i checked all my charge line connections, main grounds, and fuses and all are good. my alt does have an internal regulator which tends to fail. so im not sure if its that or not. just tryna get ideass. thanks guys
-Youtube Channel
Old 07-23-2011, 06:49 PM
Make sure to check the voltmeter as well. Mine was dipping into the 12s and it was a loose ground, lol.
Old 07-23-2011, 07:14 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
i put my dmm on the battery and the amp terminals and its accurate. the alt is working just like it should. the voltage goes up with rpm and stays constant after about 1800 rpm. it just seems as if the output has been cut it half, if not more. if im in sitting in drive with my foot on the brake, it goes down to 13.3. pop it to neutral it goes up to 13.7. give it gas its back up to 14.4. its all uniform
-Youtube Channel
Old 07-23-2011, 10:57 PM
Rayo187's Avatar
0/11 sssss1127
Feedback Score: 31 reviews
My MotorCityReman did that too when the brushes wore out....You might just need some new brushes..It worked for me..
Old 07-23-2011, 11:01 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
how do i replace them? is it difficult? where can i get them from and how do i know which ones i need?
-Youtube Channel
Old 07-23-2011, 11:28 PM
Rayo187's Avatar
0/11 sssss1127
The Brush Assembly is underneath the Voltage Regulator..Remove the Torx screws holding the Voltage Regulator in place..Then you will see the brushes...You have to take two Torx screws out to remove the Brush Assembly from the Voltage Regulator...Very Simple..
Here's a link to a place online that sells the Brush Assembly that includes Brand New Brushes:
Brushes= Part No. 392021
Voltage Regulator= Part # 352021 Voltage Regulator for Ford Motorcraft 2G series Alternator
Good Luck!
Old 07-23-2011, 11:42 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
did you have to replace the regulator in yours? and did the brushes make it perform like it had in the lpast? also, just to clarify, those are the brushes supposed to be used in my alt? thanks for that btw... only reason i ask cuz here 91-96 Escort 1.9L it says its a 3G alt
-Youtube Channel
Old 07-24-2011, 12:16 AM
Rayo187's Avatar
0/11 sssss1127
I replaced the Voltage Regulator and Brushes together...I had a spare Voltage Regulator with good Brushes in it...After that it performed like new again..My mistake on the part #'s...You do have a 3G..
Try these part #'s
Brush Assembly:Part # 39207 Brush Holder Assembly for 3G Series Alternators
Heavy Duty Voltage Regulator: F794HD Heavy Duty Voltage Regulator For: Ford 3G Series Alternators Used On: Ford, Ford Truck, Lincoln, Mazda, Mercury Lester Nos: 7749, 7750, 7751, 7752, 7753, 7755, 7756, 7760, 7764, 7765, 7768, 7769, 7771, 7776, 7778, 7785, 7790, 7791
Old 07-24-2011, 12:31 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
orderes both. hopefully itll work for a while. if not, ive emailed all the major alt companies about doing a custom alt for my car; since no one makes one. thanks again for the help man
-Youtube Channel
Old 07-24-2011, 12:37 AM
Rayo187's Avatar
0/11 sssss1127
Np..
alternator klilflipp Wanting to Buy (WTB) 1 03-07-2011 08:55 PM
Alternator VW CC aottley General Car Audio Discussion & Questions 1 11-29-2010 05:33 PM
alternator klilflipp Wanting to Buy (WTB) 5 10-29-2010 11:53 PM
h/o alternator munches4bass General Car Audio Discussion & Questions 1 05-20-2010 09:33 AM
I need a H/O alternator themgators511 Wanting to Buy (WTB) 23 02-18-2010 03:37 PM
