need a answer? - Car Audio Classifieds!
Old 07-24-2011, 12:06 PM
0/11 ssssss378
Question need a answer?
i just hooked up a shuriken 60 amp hour batt and a power acoustik 20 farad cap in my trunk im running the battery off of my batt under my hood and the cap off the batt in the trunk some times my cap reads at 14 and sometimes at 12 volt? and sometimes when the system is up it drops to 11 and sometimes all the way to 9? what could be the problem? sometimes my eq dims really low and sometimes it dosent? lol!!!! the radio never dims nor the lights? what could this be? little help thanks!
Old 07-24-2011, 12:09 PM
0/11 ssssss410
Are the drop times during bass notes?
Old 07-24-2011, 12:14 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
im sure you checked grounds, but it sounds similar to a alt starting to fade away
0/11 ssssss378
yea but they dont always go that low? are you supossed to charge the cap up before installing? does it matter if i just hooked it straight up? i read somewhere that u had to charge it? if i leave the car run for awhile it will read 14 all the time if i just get in and crank it it goes low? do i have to let the car warm up before all tis?
Old 07-24-2011, 12:15 PM
sthrnbumpn's Avatar
0/11 sssss2961
im sure you checked grounds, but it sounds similar to a alt starting to fade away,
thats a lot of load on your alternator
Old 07-24-2011, 12:18 PM
sthrnbumpn's Avatar
0/11 sssss2961
it does a take a mintue to charge the cap, but nothing to noticeable, couple quick revs around 2k rpm's should help with your alt chargeing it up
when u first start up
Old 07-24-2011, 12:29 PM
massivespl's Avatar
0/11 sssss8409
i'd take that power acoustik 20 farad cap right out of there. see how that works
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
0/11 ssssss378
should i get rid of one of them? the bat or the cap? what is better to have? im just running 1 12 inch pioneer and 4 10 inch ev's and 2 lanzar opti 500.2 amps? ?? what should i do i dont wanna fry my alt no money to get a beefed up one at this time?
Old 07-24-2011, 12:34 PM
massivespl's Avatar
0/11 sssss8409
keep the BATTERY and get rid of the power acoustik 20 farad cap. and y are u running a 12 and 4 10's? i'd just run the 4 10's... alot of ppl say you dont want to run different size subs in the same setup do to sound canceling...
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 07-24-2011, 12:35 PM
mega fatty
0/11 sssss6008
take out the cap, check all grounds, this includes the grounds on the frame up front and to the engin block
next disconnect your rear batt and have autozone or somewere test your front battery, it could be dying and killing your other batt. next i would replace the front batt because im assuming its a wet cell and the shuriken is agm, which dont really like to be mixed
did you do your big 3 upgrade?
07 mazdaspeed3
rd d9 @ .5ohm
Any questions you just couldn't get an answer to.. I can help. iamsonic New Member Orientation 47 10-14-2017 11:54 AM
no answer AQ jorgesau100 General Car Audio Discussion & Questions 4 06-21-2011 05:23 PM
Does anyone answer emails @ AQ ?? Magnet General Car Audio Discussion & Questions 18 06-07-2011 03:35 AM
Need Answer Asap jt_buck General Car Audio Discussion & Questions 10 04-11-2011 07:35 PM
Answer me this, would you rather... k3n12ock General Car Audio Discussion & Questions 16 05-25-2010 03:08 PM
