Ok so how much wattage can I actually support? - Car Audio Classifieds!
Old 07-24-2011, 08:41 PM
0/11 sssssss79
Default Ok so how much wattage can I actually support?
I know I started a thread about 2500 rms support ... but what could I truly be capable of supporting?
I will have a 250 amp alternator .
the rest is unknown and upto you to tell me how many batteries I would need to support what power.
Old 07-24-2011, 08:45 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
2500 watts is about 250 amps depending on witch amp you'll be running. So the alt will be good for just the sub amp. You'll need batts or whatever to support the cars electrical and your other audio equiptment. grab a 3100 or two.
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
I run a 2500rms amp on a 170 amp alt and a xs power d3400 under the hood. Single run of 2/0 and grounded to the frame. Stay in the high 13's worst case while driving
-Youtube Channel
Old 07-24-2011, 08:51 PM
0/11 sssssss79
what if I wanted to run between 6 to 9 thousand watts ? is there any way of judging on how many batteries are needed to run a setup for like 15 minutes or so ?
Old 07-24-2011, 08:55 PM
Anotherguy's Avatar
Active Member
0/11 ssssss605
That's what I'm gonna be running and I'm doing it with a 250 amp alt and 4 XS D3100's
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
wise man once told me 70 ah for every 1000 watts.
Old 07-24-2011, 09:06 PM
0/11 sssssss79
alright cool DJ ...so if I run 6 3100's do u think id see alot of voltage drop?
Old 07-25-2011, 02:49 PM
0/11 ssssss181
You will always have some voltage drop unless you ALT supplies more amps then everything in your car draws. But this should be a good setup for a weekend competitor. More batts couldnt hurt. This is of coarse if you dont ride around full tilt all the time.
Old 07-25-2011, 03:35 PM
0/11 sssssss22
Should work fine for the 2500. With a couple 3100s you shouldn't see too mug voltage drop and be able to play for a while.
Old 07-25-2011, 04:40 PM
LEN671's Avatar
BASSHEAD from Guam!!
0/11 sssss1148
i am running my setup in my sig off of a Stock Alt. And i don't have alot of voltage drop.
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
2/0ga. WIRE THROUGHOUT
Team DC Audio 2012
Wattage @ 17.5 volts? kmanian1 (Sundown Audio) 43 05-29-2011 11:57 PM
Wattage distribution Vital General Car Audio Discussion & Questions 4 01-31-2011 11:52 AM
which is better in wattage JAYARE2007MAG General Car Audio Discussion & Questions 20 11-06-2010 02:25 PM
Amperage and wattage SPL Guru General Car Audio Discussion & Questions 7 10-09-2008 09:35 AM
RE SE wattage estimate Patrick Simmons General Car Audio Discussion & Questions 11 09-15-2008 09:55 PM
