Respectable db level for my setup? - Car Audio Classifieds!
Old 07-24-2011, 11:49 PM
0/11 ssssss247
Default Respectable db level for my setup?
I have an SA-15 powered by an SAZ 1500 at 2 ohms. I am in the process of building the box to face forward and the front of the box will be about wear the rear seat used to be (it's been removed) I will be sealing everything off from the trunk of course. I am also making the big 3 upgrade with knukonceptz 0 gauge cca as well as running the same wire to my amp for power and ground. After all is said and done what would be a respectable db level for that set up? Not looking to blow anyones mind with it just respectable.
Old 07-24-2011, 11:52 PM
J&T DESIGNS's Avatar
0/11 ssssss791
Low to mid 40's
db Revolution
J&T DESIGNS
Old 07-24-2011, 11:53 PM
0/11 ssssss247
That would be awesome. My goal when I first got the sub was 140. The car is also a 1990 toyota camry....don't know if that effects anything or not, haha.
Old 07-25-2011, 12:14 AM
mylows10's Avatar
0/11 sssss2210
Feedback Score: 17 reviews
high 30s
Old 07-25-2011, 12:22 AM
LEN671's Avatar
BASSHEAD from Guam!!
0/11 sssss1148
Mid 140's possibly. But that is if you build your box right.
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
2/0ga. WIRE THROUGHOUT
Team DC Audio 2012
Old 07-25-2011, 12:23 AM
LEN671's Avatar
0/11 sssss1148
Where are you porting your box?
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
Team DC Audio 2012
Old 07-25-2011, 12:26 AM
0/11 ssssss247
I've already built the box and tested it out, and it is significantly better sounding than my old one. Not sure how good it is in the grand scheme of things, though. I'm out of town right now or I would give you the box and port dimensions.
Old 07-25-2011, 12:27 AM
Unleash The Beast
0/11 ssssss245
All depends on the box and what you want the port frequency to be at.
Check out my ride
Did I help you out?
Don't forget to hit thanks ------->
0/11 ssssss247
I put a slot port on the front facing the same direction as the woofer on the drivers side.
Old 07-25-2011, 12:28 AM
0/11 ssssss247
Box is tuned to about 32 hz
[SOLD]3 DC Level 4 18s Dual 1 With Level 5 Coils fijunkie88 18" Subwoofers 25 02-04-2011 01:55 AM
whats the difference between a level five and a level four with a level five coil? mattintc10 (DC) 29 02-03-2011 11:12 AM
D1 15 inch dc audio level 4 with level 5 coil rachidfunaki 15" Subwoofers 43 06-22-2010 01:56 AM
[Sold](2) DC Audio Level 3 12s with Level 4 D1 coils Like New! toaster 12" Subwoofers 12 03-30-2010 07:09 PM
[TRADED] DC level 4 15's w/level 5 coils and xtra spider Violence* 15" Subwoofers 16 01-15-2010 11:53 PM
