gremlins in my sub stage? - Car Audio Classifieds!
Old 07-25-2011, 03:28 PM
808kikdrum's Avatar
team IAK
0/11 sssssss86
Default gremlins in my sub stage?
first heres the system rundown-kdcx991 w/ipod in glove box(sub setting at 0, lpf @70hz), rf t400-4, aq2200d(no bass boost,subsonic @ 25ish hz, lpf wide open), rf t1652s comps, aq hdc3 15 d2(coils each read 2.1) @1ohm, 3.8cu/ft aero @34hz, xs d2400 under hood, deka g31 in trunk, all 0ga between batts and 2200, 4ga for t400-4.
so out of nowhere the lows sound substantially weaker and plain chitty,higher bass is substantially louder but again chitty. sounds like systems ive heard with gain set way high. peaky and uncontrolled, ive checked the sub(thought maybe lost spider/s) nothing i could see or feel, still stiff, played free air and nothing was obvious. changed rca's, grounded rca's, checked all power, ground, remote, speaker connections, checked box for any leaks, disconnected remote gain, played with all amp and head unit settings. Currently gain is set low at under 1/4, doesnt sound as bad at low volume but who likes low volume?. At this point im really thinking/hoping its a sub issue but dont know how to be sure. Any other ideas/things to check or try? thanks gents.
Old 07-25-2011, 03:44 PM
0/11 ssssss181
did you try each voice coil seperatly?
Old 07-25-2011, 08:24 PM
808kikdrum's Avatar
team IAK
0/11 sssssss86
yep, both sound the same....chitty
Old 07-25-2011, 08:27 PM
davecubs14's Avatar
0/11 sssss1845
Maybe the baby broke it? Lol.
But do you have another sub to try the amp on, cause if you do that, it should eliminate all other possibilities besides the subs.
2001 2 Door Blazer -
'11, '12, '13, '14 Meca Street 2 AL State Champ
AL Meca Street 2 Record Holder(151.6)
2012 Meca World Finals - Street 2 - 3rd Place(148.7)
2013 Meca World Finals - Street 2 - 2nd Place(151.1)
2014 Meca World Finals - Street 2 - 2nd Place(152.3)
Old 07-25-2011, 08:47 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Might be a dying amp.
My Car, My Ears.
Old 07-25-2011, 08:51 PM
Jokerr's Avatar
0/11 sssss2279
Feedback Score: 33 reviews
Check if you box was compromised during a ridiculous bass line
I buy blown amps,
Old 07-25-2011, 08:52 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
and what do you mean by LPF "Wide open"?
Old 07-25-2011, 08:55 PM
808kikdrum's Avatar
team IAK
0/11 sssssss86
if she broke it its comin outta the college fund, no xtra subs here to test with, feel free to send me one tho. what are some symptoms of dying amp syndrome that i can test for and how?
Old 07-25-2011, 08:59 PM
808kikdrum's Avatar
team IAK
0/11 sssssss86
i mean its all the way up, not being used.
Old 07-25-2011, 09:04 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
well that could have caused an issue. its not typically advised to run subs of this stature and power levels above 80-100hz. i could imagine lower voices and other sounds could fiddle with the action of the sub at higher power
-Youtube Channel
Tags
issue, lake titticaca, problem
Front stage ModFreak General Car Audio Discussion & Questions 3 07-31-2010 05:32 PM
Help with sub stage amp Biggman44 Off Topic Chat 4 03-04-2010 07:54 PM
Front stage help gbo559 General Car Audio Discussion & Questions 22 09-22-2009 01:24 PM
front stage slammed636 General Car Audio Discussion & Questions 11 07-28-2009 07:57 AM
Sub Stage Help DLP customs General Car Audio Discussion & Questions 11 11-05-2008 11:07 AM
