batts and voltage - Car Audio Classifieds!
Old 07-25-2011, 04:31 PM
0/11 ssssss939
Default batts and voltage
In my car I had 1 stock battery up front a 110 amp alt with big 3 done, all 0 gauge wire with 2 super start fleet and heavy deep cycle batts in back. Those were running a sundown saz1500 at .5 but on amp said it was only getting 11 volts when batts said not below 13.7, so I have upgraded to a sundown saz2500 amp and changing back super start batts with 2 deka 9a31 batts, still 110 amp alt with big all 0 gauge wire but still front batt is stock. With the new dekas in back should it give the saz2500 what it needs for at 1ohm or do I HAVE to REPLACE front batt even if it's good to a dry cell or sealed agm to get a diff response to amp. What I am really asking is do I have to replace front batt to get voltage up to the amp or will the dekas be enough for now.
Old 07-25-2011, 04:36 PM
0/11 ssssss181
front should be fine. You need to look at wiring. What kinda car is this cuz i see your name is Lincoln Ls and thats what I have
Old 07-25-2011, 04:52 PM
0/11 ssssss939
Well I have a 2002 mitsubishi diamante and got rid of lincoln. I was thinking to upgrade front batt to one of my deep cycles. Also I have front batts pos to back batts pos and every amp and battery has its own ground. The pos goes from back 2 the 2nd back batt then to the amp. Batts are connected with 4 gauge, but front to rear batt is 0 gauge, and from last batt to amp is 0 gauge.
Old 07-25-2011, 05:46 PM
0/11 ssssss181
sounds wired up fine. All batts pos connect. All batts have short grounds. I would do all 0 Ga but I dont think that one piece of 4 is killing you. I would really look at your grounds. Makes sure its a good connection and bare metal. The front Batt shouldnt be hurting it really. However if you need a reason to change your front Batt I have heard its bad to run Diff types of batts in the same setup. Has anyone else heard this also?
Old 07-25-2011, 05:55 PM
0/11 ssssss939
Grounds are all wired in trunk and yes took grinder to all metal so yes it's bear metal. I will go ahead and run o gauge were 4 is, also has any one heard if it hurts to run ground of amp to the ground of the battery? also There is no way for me to run a deka 9a31 batt up front so hope you can run diff batts!!!!!
Old 07-25-2011, 06:41 PM
0/11 ssssss181
you should never run the amp ground to battery ground because of noise.
Old 07-26-2011, 03:11 AM
0/11 ssssss284
ive always ran the ground from the amp back to the battery never had a problem with noise. grounding to bare metal on the body isnt all that great imho especially for larger amps. ive done it and had a really bad drop but none when running a line back to the battery.
Old 07-26-2011, 04:17 AM
nuboot's Avatar
0/11 sssss1775
Feedback Score: 24 reviews
i ran 4 runs of ground from my front battery to the battery bank in the back and still dont get any noise
VEHICLE: 2005 Trailblazer on 24s
WIRING: 8 runs of 1/0 knu gnd and pwr
BATTERIES: 4 Shuriken BT80s
AMPS: Team Cactus 5k
SUBS: undecided
batts howyadoin General Car Audio Discussion & Questions 0 06-04-2011 09:32 PM
How many batts do I need? ray60218 General Car Audio Discussion & Questions 34 04-01-2011 09:30 PM
Who knows batts? Bologna General Car Audio Discussion & Questions 25 04-19-2010 10:18 PM
2 vs 4 batts, will it make a big different in voltage? Vaginatarian General Car Audio Discussion & Questions 17 02-09-2010 12:37 PM
Resting voltage of 16v batts ssackett General Car Audio Discussion & Questions 19 02-03-2010 10:34 AM
