A little help. - Car Audio Classifieds!
Old 07-25-2011, 08:22 PM
Brand New Members
0/11 ssssssss1
Default A little help.
Does 2 HDC312 and a AQ2200D amp require the BIG 3?
Old 07-25-2011, 08:24 PM
GoodyearJason's Avatar
0/11 sssss1398
Big 3 is always a good idea
Kenwood KVT-514, Clarion EQS746, Singer Alts, Ampere Audio amps
Old 07-25-2011, 08:38 PM
0/11 ssssss181
car audio requires the big 3 lol
Old 07-25-2011, 08:40 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I would advise it, but A 2200 will be under powering those subs. Some of the RMS ratings on the more reputable companies are lower than the woofer will take, this is especially true with DD and AQ woofers.
Old 07-29-2011, 04:31 PM
Eazye420's Avatar
0/11 ssssss279
If you took the two aq subs down to 1 ohm, 2200 watts x1 would be under-powering them? They're 1000w rms right? just askin..
Old 07-29-2011, 04:34 PM
RE_XXX's Avatar
0/11 sssss3181
Those subs will take a good 2k-3k a piece
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
Old 07-29-2011, 04:36 PM
0/11 sssss1398
Not too sure if the AQ2200 will do rated power either
Old 07-29-2011, 04:37 PM
dadydolas's Avatar
Loyal Member
0/11 sssss1744
Feedback Score: 22 reviews
I wouldn't say you are under powering them but they are certainly able to take more power and continue to improve by almost all accounts.
Old 07-29-2011, 04:39 PM
Eazye420's Avatar
0/11 ssssss279
Default 2-3k
Wow, I just didn't know the capabilities of them I guess. I've actually been thinking of getting a set myself over the past week or two. I was gonna match each sub up with a AQ2200D Amp. So i should be good if wired right.
Now I'm thinking about my amp choice..... Still gonna go with the HDC312's though!
Old 07-29-2011, 04:43 PM
RE_XXX's Avatar
0/11 sssss3181
Amp choice is fine! Do a 2200d per sub and if installed correctly will do what your wanting them to
