i kno u guys love to answer questions :P - Car Audio Classifieds!
Old 07-25-2011, 09:27 PM
0/11 ssssss141
Default i kno u guys love to answer questions :P
ok. 2 twelves in a ported box. im gunna havem in my trunk firing into the cabin with the seats down (or taken out) and sealed off from the trunk with the port also facing the cabin (most likely ). but im wondering if a common L port will please the TL more than having the port between the two subs. assume all variables are the same and the boxes would both be made with great quality.
Old 07-25-2011, 09:30 PM
J&T DESIGNS's Avatar
0/11 ssssss791
That's a matter of testing.
db Revolution
J&T DESIGNS
Old 07-25-2011, 09:32 PM
0/11 ssssss141
figured as much lol
Old 07-25-2011, 09:57 PM
0/11 ssssss181
testing will tell you for sure but usally port further from the mic. so port on drivers side yields the best results. But thats not a garentee.
Old 07-25-2011, 10:02 PM
Captain Tying Knots
0/11 sssss1220
make sure you seal it well. if you dont you might as well go subs back port back. the easiest way to do it would be to use aeros and then cut em down until you stop making gains. and you could try 3 baffles. one with port on drivers side, one with port on passenger side, and one between the subs
TEAM NWSPL
Old 07-26-2011, 11:10 AM
0/11 ssssss413
What seems to work well in trunk cars is port driver side, subs forward.
Any questions you just couldn't get an answer to.. I can help. iamsonic New Member Orientation 47 10-14-2017 11:54 AM
need a answer? kevmoney265 General Car Audio Discussion & Questions 18 07-24-2011 12:54 PM
rd audio questions that noone seems to be able to answer nightshade27 General Car Audio Discussion & Questions 1 04-01-2011 10:44 PM
anyone kno what kind of 6.5s these are? GODHATESCIVICS General Car Audio Discussion & Questions 14 08-31-2009 12:37 AM
