do i need higher output alternator? - Car Audio Classifieds!
Old 07-26-2011, 11:44 AM
0/11 sssssss34
Default do i need higher output alternator?
so my alt is bad and am replacing it. oem 2000 nissan altima alt put out 100 amps. i got a aq4x90 right now and am purchasing either a aq1200d or an sax-1200d to run my sa-112.
do i need a higher output alternator or will i be fine just buying an oem alt?
i have already gotten one oppinion that said stock electrical is fine but everything i have read says anything past 1200 watts or so you should upgrade and im guessing ill be at about 15 or 1600ish?
p.s. i play my music at 3/4 volume upwards of an hour continuously twice a day to and from work, so going a little overboard on electrical to lengthen the life of my amps is fine by me.
Old 07-26-2011, 11:46 AM
0/11 sssss1381
just get a good battery the biggest xs power one you can fit and do the big 3
Old 07-26-2011, 12:23 PM
0/11 sssssss34
it will give me good clean power for long periods of time? im just makin sure cause ive read in a lot of posts that if your gonna push an sa-12 with 1200 daily its important you give it really clean power. basically i wanna be able to turn it all the way up for loong periods of time and never have to worry about a voltage drop or anything
high output alternator? mrtopnotch561 General Car Audio Discussion & Questions 1 06-08-2011 05:38 PM
high output alternator thekernal123 Wanting to Buy (WTB) 2 02-15-2011 10:26 PM
High output alternator ckaiser1688 General Car Audio Discussion & Questions 6 02-11-2010 03:52 PM
High output alternator. basshead08 Wanting to Buy (WTB) 0 10-06-2009 08:31 PM
