2 AQ 2200 Question - Car Audio Classifieds!
Old 07-26-2011, 08:34 PM
Awaiting Confirmation
0/11 ssssss153
Default 2 AQ 2200 Question
okay so i want to here what ppl have to say on this. What would you do? would you strap two AQ2200 or would wire each to each sub and mach the gain and lower the ohms?
Old 07-26-2011, 10:47 PM
Nebraskachevy's Avatar
0/11 ssssss518
strap them, also the ohm loads would be the same, if you had a dual 1 sub, and wired at 1 ohm on each amp, that would give you 4400 watts, but if you wire to 2 ohms and strap the amps, each amps sees 1 ohm, so you get the same amount of power
Ford Ranger
AQ1200D + AQ HDC318
Treo ssx100.b, Big 3 in KCA 1/0, 2/0 Welding to Back Battery
Sundown Sax100.2 + Crescendo CCX6.5
139.2 @ 41 Hz, Wired to 2 ohms
Old 07-26-2011, 11:05 PM
0/11 ssssss189
strapping them is easier(one bass knob and one amp to tune) and I don't really see any advantages of wiring up individually
Amps=Crescendo BC5500(subs) C1600.2(mids) & Autotek MM1600.2(tweets) Subs=2 HDC312s Mids/Highs=Crescendo MP8s and 6.5s, AQ PA 6.5s & Supertweeters Electrical=220 amp EA alternator,3 BT100 batteries in the bank & about 75 feet of 0gauge KNU wire...
Old 07-26-2011, 11:54 PM
0/11 ssssss153
True on the bass knob but if I didn't link them I could wire them down to .5 ohms.
Old 07-26-2011, 11:56 PM
0/11 ssssss518
you mean both amps running at .5 ohm individually?? You cant wire them strapped to 1 ohm though?
Ford Ranger
AQ1200D + AQ HDC318
Old 07-27-2011, 04:36 AM
0/11 sssssss60
strap them!
Old 07-27-2011, 12:32 PM
0/11 ssssss153
yes running individually at .5 ohms. so then they wont be linked.
Old 07-27-2011, 12:38 PM
98AckCL23's Avatar
0/11 sssss9929
So, you have Dual 1 ohm subs, right? If you can go .5 to each amp, then you can strap at 1 ohm, so each amp see's .5 ohms individually. From an ease of doing things standpoint, you can't beat strapping. If you're looking for every last .1db, then there is some thinking out there that you will gain .1-.2 by not strapping. It works for some people, doesn't gain others anything. You'd have to test it...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 07-27-2011, 01:18 PM
0/11 ssssss153
Thanks for your input.
Tags
aq2200, aq2200d, audioque, mono amp, mono amplifier
AQ 2200 Question josh09 General Car Audio Discussion & Questions 14 07-25-2011 11:15 PM
Aq 2200 BlaneC Mono Amplifiers 2 07-01-2011 01:49 PM
aq 2200 alex95sl2 Broken & Non-working equipment 8 06-18-2011 04:29 PM
aq 2200 amp question BLACK MOUA DC BOY General Car Audio Discussion & Questions 1 04-05-2011 12:30 AM
aq 2200 question?effiency at 1ohm bobbyh3342 General Car Audio Discussion & Questions 3 07-22-2010 11:12 PM
