Extra run of 1/0 to back make a diffrence..... - Car Audio Classifieds!
Old 07-26-2011, 09:00 PM
03navi's Avatar
Feel The Bass!
0/11 sssss1505
Default Extra run of 1/0 to back make a diffrence.....
will an extra run of 1/0 gauge from the front batt to the rear batt make a diffrence in any way?
voltage?
Amps?
"This next song goes out to everyone within a 3 block radius"
100% FeedBack on eBay
Old 07-26-2011, 09:04 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
need a lot more info
Old 07-26-2011, 09:05 PM
mylows10's Avatar
0/11 sssss2210
Feedback Score: 17 reviews
yes
Old 07-26-2011, 09:17 PM
grocerygetter's Avatar
New build coming soon?
0/11 ssssss583
it will help you carry more current back to your rear batts. 1/0 can only handle so many amps so more runs improves your voltage because it helps recharge your batts faster. if you're really draining voltage that much you should probably get a H.O. alternator
Old 07-26-2011, 09:24 PM
Veteran Member
0/11 sssss3026
the extra 1/0 will ONLY help if you need it.
if your running 2kw and already have 1 1/0 and a frame ground a 2nd 1/0 will do very little for you.
if your running 10kw and 3 300a alternators but only 1+ and 1- then adding a chassis ground and a 2nd + run will make a huge difference.
Old 07-26-2011, 09:26 PM
0/11 ssssss583
very well put sir. agree'd.
how to properly run an extra battery fast4me80 General Car Audio Discussion & Questions 39 07-27-2011 07:07 PM
Legal/moral ways to make some extra cash? grimreper912003 Off Topic Chat 34 08-03-2010 10:47 PM
Extra/Back-up battery help BlueLude General Automotive Chat 2 06-19-2010 06:15 PM
Diffrence APX and APXX? Biggy General Car Audio Discussion & Questions 15 03-13-2010 10:21 AM
how big of a diffrence scfaust Enclosure Discussion & Design Construction Help 5 05-29-2009 11:18 PM
