meca/trailblazer help - Car Audio Classifieds!
Old 07-27-2011, 07:33 AM
Ego Crusher
0/11 sssss1834
Default meca/trailblazer help
I need help with trailblazer owners that compete in meca or meter at the headrest meca style. What is the best way to have your seats and doors and such to get the best score?
06 trailblazer ss (Ego crusher)
Texas speed forged 408,custom cam, stalled
hp numbers coming soon
focal 4.160,fosgate coax in rear doors
popcorn sounds 6k ,2 sundown sa15, in a 6th
Old 07-28-2011, 08:30 AM
Ego Crusher
0/11 sssss1834
noone?
Old 07-28-2011, 08:47 AM
0/11 sssssss25
Haven't personally used a Trailblazer but most of the vehicles we do at our shop for MECA we do with all windows up and driver's door open. Some vehicles do better with door closed and window down. The best way to find out is to do some testing if you have access to a meter.
Old 07-28-2011, 08:52 AM
TeamOSC's Avatar
0/11 ssssss207
every setup/vehicle is gonna meter different almost 100% of the time.it's gonna come down to trial and error.try w/your seat all the way foward and the opposite side window down to start
Team O.S.C.
Team XS Power
Old 07-28-2011, 08:58 AM
0/11 ssssss161
You will be able to manipulate your door and or window during your run.
Here are some of the configurations you need to try:
Seat forward.
Recline position as close to straight up as possible
Rear Seat up
Rear Seat down
Fire up with the sub
Fire back with the sub
Sub up port back (typicaly a good configuration)
Sub back port back
Seat down sub forward port back
Distance of the box to the loading surface
The Following User Says Thank You to Soapbox For This Useful Post:
bottlefed1 (07-28-2011)
Old 07-28-2011, 09:06 AM
Ego Crusher
0/11 sssss1834
Seat forward.
Rear Seat up
Rear Seat down
Sub back port back
Sorry I might not have been clear with what i was asking. your post was helpfull mainly im looking for like seat placements door positions, window positions, box moved foward or back. unfortunatly I cant change the box type. Its currently a sub back port back both on the passenger side
Old 07-28-2011, 09:23 AM
0/11 ssssss161
Since it is on the passenger side mic on the drivers side. Have the opposite window down and while you are burping close the door and you should be good to go. As for box placement there are quite a few factors you really consider such as: tuning, loading, distance to the mic and reflective surfaces. How much work have you done on your rear doors? My results in my hatch varied a lot from firing in all the different positions but in all circumstances I found firing in the corner worked best when no prep work had been done to the car. Try and use as much logic as you can and think about it before you test. (it is better to fire at a corner because it it stronger than a un foamed or un deadened area). One of the things our team is investing is a extra mic so we can meter from both seats when we test.
meca mic trailblazer help bottlefed1 General Car Audio Discussion & Questions 12 06-21-2011 10:32 AM
trailblazer help bottlefed1 General Car Audio Discussion & Questions 16 10-25-2010 03:07 PM
03 Trailblazer help Scapelli21 Enclosure Discussion & Design Construction Help 37 02-19-2010 12:58 PM
04 Trailblazer Take 2 Andrew Member Rides & System Pictures 45 02-17-2010 10:55 PM
My '04 TrailBlazer LT Andrew Member Rides & System Pictures 18 09-22-2008 11:31 AM
