How to correctly wire this woofer? - Car Audio Classifieds!
Old 07-28-2011, 12:25 PM
Nik592's Avatar
0/11 sssss2000
Default How to correctly wire this woofer?
I got an AQ HDC 18' from a member on here, met him through craigslist and got this sub
my question is since it has direct lead wires and is a D4
How do I properly wire it?
if I tie the two pos wires together and put them to one terminal, and the same with both neg wires what ohm is that producing?
I checked out Rockfords wiring wizard and that makes sense to me but i guess I'm just lost with the direct connections
Thanks in advance
"Insert witty signature here"
Old 07-28-2011, 12:38 PM
Captain Tying Knots
0/11 sssss1220
Thanks in advance
you could always try bolt terminals. each lead connects to a bolt and then you can wire it from outside the box. you can wire to 2 (parallel) or 8 (series)
TEAM NWSPL
Old 07-28-2011, 12:48 PM
Nik592's Avatar
0/11 sssss2000
The box I have is custom made for the sub and has no terminals just two holes in the back to run the wires through, I'm not looking to modify anything today because I'm on pretty limited time, what is the best route to run this sub in parallel to 2 with my situation?
Old 07-28-2011, 12:50 PM
0/11 ssssss413
Imagine the tips of the direct leads as the bolt/spring terminals.
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
whats ur amp
-Youtube Channel
Old 07-28-2011, 12:54 PM
Nik592's Avatar
0/11 sssss2000
running the T1500BDCP for right now
I'm still not sure how to analyze this, im so used to pre-fab boxes from Atrend or whatever else ive used, ive always just had the subs either wired in already or did em up and just clipped the speaker wire from the amp into the box terminals
do i just tie the pos wires from each coil together and same with neg wires and then tie each respectively to the amp pos and neg speaker wires?
Old 07-28-2011, 01:04 PM
0/11 ssssss413
That's exactly what I'd do.
Old 07-28-2011, 01:05 PM
Nik592's Avatar
0/11 sssss2000
so ill be ok then? gooood =D
what Ohm is that then?
Old 07-28-2011, 01:11 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
alright heres what u gonna do.lol. get you a piece of 10 gauge or something. run it from your amp, through the hole(s) of the box for the wire. on the sub, twist the two positives together, and the twist the two negatives together. then, hook the positives up you twisted to the positive you ran from the amp, and the negatives to the negative. i always just twisted all the wires and used wire nuts to secure the connection with a little zip tie aroudn the group of wires to keep the stress off of it. you can get real big wire nuts from the hardware store. you're now at 2 ohm. make sure to use some caulk or something around the wire comming into the box as it will likely leak air
-Youtube Channel
Old 07-28-2011, 01:13 PM
Nik592's Avatar
0/11 sssss2000
now ur talkin my language..haha
thanks for the help, thats how i planned on running it as well,
definently need something to secure the wires to each other =/
im running JL 8 guage from the amp to the leads, leads are also 8 ga
how to set your system up correctly korey_hofer Sound Quality Area 24 02-22-2011 07:55 PM
setting up gain correctly midnite toka General Car Audio Discussion & Questions 34 04-26-2010 08:36 AM
Was my box tuned correctly? vicon4z General Car Audio Discussion & Questions 20 08-04-2009 05:35 PM
Crossover Lesson (is your passive crossover labeled correctly?) iamsonic Tutorials & Quick References 0 01-20-2009 07:05 PM
[MODERATE] How To: Set Your Amplifier Correctly danteBirosel Tutorials & Quick References 3 11-12-2008 02:20 PM
