building a car audio test bench, how to? - Car Audio Classifieds!
Old 07-28-2011, 11:08 PM
0/11 sssss8594
Feedback Score: 55 reviews
Default building a car audio test bench, how to?
im looking to make a test bench for all my car audio needs/wants...what am i looking for...what do i need to make this work??...also, how exactly am i gonna wire it up??...it confuses me not having an ignition switch to plug into but im sure theres a way to make one or something similar, im just not aware how
so far, i know im gonna need
1) headunit
2) battery
3) sub(s)
4) sub amp(s)
5) speakers
6) speaker amp(s)
Enclosures
Old 07-28-2011, 11:12 PM
0/11 ssssss288
No idea on the actual set up, but when going without an ignition/remote I'd assume that a toggle switch would do the trick. Wire starting at battery, to switch, to Remote input on amp/HU. Easy peasy
Old 07-28-2011, 11:19 PM
3rdshiftdiscretion's Avatar
CACO Late Night Crew
0/11 sssss4240
Feedback Score: 30 reviews
my remote wire is on a toggle switch in the car anyways...
Bewbs
Old 07-28-2011, 11:21 PM
0/11 sssss8594
would that save all of my h/u settings having the toggle switch??
Enclosures
Old 07-28-2011, 11:26 PM
0/11 ssssss288
Remote is the "Start working damnit" wire. The constant 12v (settings saver) I think is usually yellow.
In this case you'd have 2 coming straight from battery, but 1 (the Remote, Blue probably) would make it's way to the switch before getting to the HU.
Old 07-28-2011, 11:27 PM
Justin's Avatar
0/11 sssss1418
Just use a power supply... And yes you can run a toggle switch if you want or just with the constant and acc together.
TEAM SUBSONIC ADDICTION
0/11 sssss8594
thats where im confused...what do i connect to the battery??...my main issue is the wiring and how to do it all
Enclosures
Old 07-28-2011, 11:30 PM
Justin's Avatar
0/11 sssss1418
You can connect the power supply to the battery and then wire it like you would a car
Old 07-28-2011, 11:33 PM
streetconcepts's Avatar
0/11 ssssss105
You won't need a battery if you use a power supply like the one I got which is a pyramid. I think it can do up to 24v.
Old 07-28-2011, 11:37 PM
Justin's Avatar
0/11 sssss1418
Well depending on what model power supply and then has to figure what kinda amperage he is gonna draw..Or want to be prepared for..
Konaki KO-3691D Amp Bench Test duramaxxed General Car Audio Discussion & Questions 21 01-11-2013 03:04 PM
How to Make a "Test Bench"?? SacTownBully84 General Car Audio Discussion & Questions 1 12-27-2010 11:26 AM
Poor Mans Test Bench Memphistahoe02 Tutorials & Quick References 5 08-20-2010 12:43 PM
Can anyone near columbia,sc bench test my amp? Jadon087 General Car Audio Discussion & Questions 8 11-01-2009 04:52 PM
